Finally ordered new front discs to go with the new pads ::)
cd 2.2
Scared myself with a code read and reset, only to find 8 miles later that the Eml came back on  ::)
chrisgixer
Quote from: cd 2.2 on 03 April 2014, 16:45:32
So, the fault is definitely present then ?
I wonder.... Would that be a cam sensor fault, per chance? ;D
cd 2.2
The cam sensor is toast .. I know that for sure but can't afford a new one till the end of the week
chrisgixer
Noticed a wheel speed related buzzing noise a couple of days ago. "Wtf is that?  >:(" I thought.
Today its a rumble. Ah. Wheel bearing. Bit early for an fag to fail I thought.
Jacked and inspected. Bearing rough with play. Cap off. Water evident inside. Bollards. New bearing cap used. Why hasn't it sealed..? Or has water got in through the rear seal on the hub side...?  :-\
New used bearing pinched off the other car. All sorted, nice and quiet. Used cam cover goo to seal the cap this time. Hopefully I won't need to take the cap off again, as it won't want to come out easily now. ::)
Blatted over to Kevins' to get my airbag light sorted...
My little hiccup managed to generate fault codes on every system except the Abs ::)
Thanks Kevin for taking the time to delete them all and for the tea :y
Unpacked an exhaust, delivered just before 8am this morning :)
joff
Quote from: TheBoy on 04 April 2014, 08:51:42
Was that the £80 ETS one ??? If so how long did it take to arrive after ordering :y
Drove it to work, thinking how smooth and silent it is  :)
Quote from: Taxi Al on 04 April 2014, 00:25:15
'twas a pleasure. :y
After that little blat you've got me hankering for a manual 3.2, though. :-\
I think I'd do without the plod lights, though. Too much temptation there. ::)
Took my Elite to have the air con fixed.
Expected to be paying for a new condenser but found that there was still (some) gas in the system.
Vacuumed out and regassed.
All set now for some warm weather  :y
Quote from: joff on 04 April 2014, 09:09:03
Answered on Jimbobs thread already :)
Quote from: Kevin Wood on 04 April 2014, 09:29:56
Lights stayed off all the way home... don't tell Andy B or that Gixer bloke about wanting a manual though... you'll never hear the end of it ;D
Quote from: Taxi Al on 04 April 2014, 11:39:07
I needed a manual "fix", as not owned one for 2 years.  I'd have an manual Omega tomorrow if the box was any good.  I did toy with converting my old TD to manual, as that didn't suit an autobox, but I think the horrible change would have grated on me every single day I used it...
chrisgixer
Have you turned Mr Wood all Edwardian Al ? :o
