All good in the end then :y
Some people would kill for their cars to drift ;D
Quote from: Entwood on 02 April 2014, 11:23:38
Quote from: Marks DTM Calib on 01 April 2014, 09:29:55
Quote from: Entwood on 31 March 2014, 21:21:25
Quote from: Taxi Al on 31 March 2014, 20:43:17
17° and dry all day here ;D
Don't worry about that bolt Nige, I've dropped two, and can't hear (or find) either of them ;D sympathise about the wishbones though nearside one is always a bastid for some reason :-\
Heat and mole grips free the rear track rods a treat :y they need to be glowing though, so wear gloves :y
Doubt I can get them that hot in situ ... weedburner is the only portable source of flame I have ... so probably have to take them off .. which knowing my luck will bugger the ball joints ... anyone know how much complete replacements are ??
Rears are dead easy, just taken them off(which is easy to do), bang them in a vice and apply some heat.
They dont need to be anywhere near glowing, they will free up long before then.
Then remove the threaded rod sections (count the turns), clean with a wire brush, apply grease and refit....they wont ever sieze again then in my experience.
Now there's a question ... which grease ??
I have Copper, High Temp Grey Lithium [Castrol LM], High Temp Molybdenum Disulphite [Castrol MS3] and a very small amount of Silicon .....
I know Chris swears by "white grease".... but that covers a multitude of varieties... so which "white" greae ?? or one of those I already have?? :)
BTW  I HATE aerosol greases.. so tubs/tubes only as suggestions please :)
Rewinding the thread a tad .... while working on the car this morning and applying generous amounts of copper grease to the new control arms, a neighbour stopped to chat and was surprised at what I was doing with the grease, until I explained ...
He has just dropped round and given me an unopened tub of some stuff he bought but never used .. its a white grease with zinc-oxide added... identical product on fleabay is
http://www.ebay.co.uk/itm/WATER-REPELLANT-WHITE-GREASE-MARINE-OR-AUTOMOTIVE-500G-TUB-MADE-IN-ENGLAND-BC41/400572055428
Is this stuff any use ???
Could use that for a myriad of things :y obvious items being sunroof gubbins, door latches/hinges, handbrake/trailer brake linkages etc :y
Probably as good as copper slip on suspension joints, not sure the temp range is high enough for brake/bearing use though :-\ Handy enough to have by the look of it :y
Quote from: Taxi Al on 05 April 2014, 16:31:29
Thanks for that .. methinks that after the geo is done on Monday I might slap a bit of that about the front TRE adjusters and the rear control arm adjusters .. some of that on top of the copper grease might just keep the corrosion at bay a tad longer !!
Shackeng
#7429
Checked the Elite's brake disc for MOT, the only rust, as listed in last year's advisory, is a 1-2mm ring on the outer edge of each rear disc. Advisory FFS. I guess they have to put something. >:( >:( >:(
Rubbed and ground out the minor rust on the inner front wheel arches. Silver Hammerite tomorrow, then underseal, to hopefully delay the welding which was required on the TD. :y
Slapped a new exhaust on the Bullet :).  Thanks to the useless student for the use of his drive and some of his tools :y
elitedave
took her for her last drive and parked my miggy for the last time :(
Shackeng
Quote from: TheBoy on 05 April 2014, 17:49:11
I thought he'd moved? :-\ :-\ :-\
Quote from: Shackeng on 05 April 2014, 18:29:46
So did his folks :P ;D
(Last night) Cut out out the useless front bushes from the spare wishbones to replace with poly, replaced front wishbones and drop links. Finished 1:30 AM  :-[ Sorry, neighbours.
Kinda had to stick with it given that the car was half in the garage. ::)
This morning, suspension setup and new front tyres. 3 new tyres for the glider trailer. FLARM collision avoidance system fitted to the glider. Bit knackered now.
chrisgixer
Quote from: Kevin Wood on 05 April 2014, 19:07:11
You should of said I could of nipped over at the weekend? Or sumat.
Anyway, done now.
;D
Never put battery on  :-[
Quote from: chrisgixer on 05 April 2014, 19:19:55
Anyway, done now.
Was sort of last minute, as I noticed the state of the front tyres, and needed to get the trailer tyres, and wanted to get the suspension set up at the same time.
Must sort out project rear donuts sometime, though.
chrisgixer
Quote from: Kevin Wood on 05 April 2014, 21:14:04
Anyway, done now.
No problem. A car park in Tadley perhaps. ;D
That'll fit in nicely between ice cream and coffee :D
