Stemo
Quote from: Sir Tigger on 28 April 2014, 17:14:56
Adjusted handbrake..... What a faff!!  ::)
Then a shitehawk faffed all over it so had to wash it.  :(
According to what I understood, growing up in Liverpool, a shitehawk is someone who hoards useless stuff (shite)
Quote from: STEMO on 28 April 2014, 18:49:16
Seagulls yer!  :y
joff
After fitting the new exhaust I was able to take the Elite out on a test drive today only to find I still have the same sound as I did driving down from Scotland on the 10th April, so back to the garage and took the rear N/S wheel off and checked the wheel bearing, well the answer is new wheel bearings on order from All German Parts, the last rears I did for my brother on his 2.2 Dti Elite estate were not as bad as this one. Don't think it would have lasted much longer, also the old exhaust had failed in tithe mid section and the back box so just as well I fitted the cat back system. Also did an oil change as not been done since I last did it before it was sold last year. Now on 82,000 miles and in need of a little TLC as cam cover on drivers side has a small leak, also need to do a auto box oil change.
joff
Removed rear N/S swinging arm to replace rear wheel bearing, two new bearing kits on order from all German parts with a 10% discount (nice). Sod of a job to do but will be back to smooooth driving when done, oh the joys of driving an Omega. Rebuild set for Saturday afternoon with just 4 x12 hour night shifts until then, I love my job I do. :D :D :D :y
Liberated an 8' branch from a tree...
Then spent my break liberating said branch from behind the cab ::)
If I hadn't then there might have been blood shed had one more person made a comment about it >:(
Suffice to say, if anyone near Badshot Lea feels an urge to, you can now get a truck down the length of Crown Lane unimpeded :-X
Quote from: Taxi Al on 29 April 2014, 21:57:19
Should have popped in for a cuppa. I've done some pruning so it'd have been fine. ::)
2boxerdogs
Fitted rear wiper blade on the 2.2, nice easy job..
biggriffin
modified trailer by,looks of picture.
Hoof'land storeman.
18t rigid :y cab tipped for access...
The dink in the frame and busted deflector were done previously by someone else ::)
Was horrified to discover a Volvo gearbox in whilst at it :o I thought that it must have been French to be so crap...
biggriffin
#7554
Quote from: Taxi Al on 30 April 2014, 10:09:24
doha! Just looked at picture again, no lines, hence rigid.
as said before Volvo running gear in dem reno's the French write there own software,hence a good gearbox ruined. :)
and lovely day on,sth coast today 8)
Hoof'land storeman.
Looking a damn sight drier than yesterday ;D
Should add, was a Volvo FL...
biggriffin
Kent was just wet yesterday.
Portsmouth today nice n sunny might need air on on. 8)
Hoof'land storeman.
Left it at home and took the bike to work, no traffic  8)
Fixed the radiator fan on the M3 over the weekend .. well, actually, I mostly stood around and supervised as two friends dismantled most of the front of the car so I could avoid crippling myself again as I had done a few days earlier.
I have discovered that there are no good DIY guides for the M3 for the jobs I want to do. I really should start writing some..
chrisgixer
Pair of rear springs and some code clearing on Pauls 2.6.
