Mr.OmegaMan
Quote from: Sir Tigger on 11 April 2014, 17:01:29
Opened the sunroof for the first time in ages.  ::)    and managed to close it before going through the carwash!!  ;D
What was ya thinking  ;D ..
Could have been well messy that, Imagine the electrical gremlins then  :o
Shame the retards are North Oxford BMW didn't, when they did the first service on my bro's £70k beemer a few years ago  >:(
Needless to say, however, he didn't get much sympathy from me :P
Keith ABS
  Took the car out for a blast up to the paintshop to see progress on the Monza
Fantastic to drive again and got to paintshop to find the Monza all painted :y :y :y
keith B
badmuver
Lagondanet
Drove home from Gloucester after a few days away in the south west (800 mile tour). Car perfect.
jonny2112
Replaced drop links (again >:().
So much easier when you jack up both sides, and have decent ratchet spanners  ;D
Does help ::)
Always a surprise just how much noise they make...
Broken it  >:(
Being alloy rather than cast iron, I've stripped the thread in one... Have tapped out and run a die over the bolt, but the thread is oppsed...
What are the options for repairing?
Tother side took really well and is fluid tight, but drivers sideis being an arse...
Presumably if I keep tapping it with an M10 tap, I'll end up with an M10 hole :-\
Quote from: Taxi Al on 13 April 2014, 17:49:23
Broken it  >:(
What have you stripped? The pictures don't help because no car I know of has cast iron wheels ???
The drive flanges are steel alloy (not aluminium) and it will take extreme abuse to damage the thread (but a windy gun & a crossed thread might do it :-\)
A good second hand flange would be the straightforward way of fixing the problem.
Quote from: Andy H on 13 April 2014, 19:39:59
Broken it  >:(
Tother side took really well and is fluid tight, but drivers side is being an arse...
The first 6 or so mm from where the brake hose banjo bolts to the caliper...
The two options as I see it are either longer bolts to reach the good thread further in, or helicoils but I'm not sure if this application suits their use, hence my separate post :-\
chrisgixer
Ah. That's annoying. :(
Bigger bolt? Won't fit the hose then, I guess. Worth a word with goodridge,? See if such a thing as an over sized banjo bolt and banjo exists, in such an instance?
Quote from: chrisgixer on 13 April 2014, 23:17:31
A bigger banjo and bolt from a different application or vehicle?  :-\
A prime bodge is in order!  :y
chrisgixer
If so, I guess a course of action would be to get a machine shop to drill and re tsp a bigger hole, and give that size to goodridge and get the new hoses made up.
I know they do custom fittings onto any braided line. Just depends if they can match the new banjo bore size on the calliper, to the rest of the omega system.
Long shot, but worth a call I guess. :-\
Bikerdon
Got started on fitting the new exhaust to the 2.6 today, had to drill out all four mounting studs on the cats, well that was a larf! NOT! >:( . Anyway got them all drilled out and the centre sections fitted before my spine finally gave out about 2 hours ago, not much fun doing that on the drive with axle stands. Will get the back-box fitted tomorrow morning.
