chrisgixer
Quote from: STMO on 12 November 2014, 18:57:40
Quote from: chrisgixer on 12 November 2014, 18:10:47
Fixed the glove box Handel, swapped out a faulty ipod cable, fitted the bt reciever that finally arrived but appears not to charge, soldered the broken wire in the external temp sensor and plugged it back in the bumper holder but not before noticing that the bumper screws where seized in. Slight blessing in disguise as I then had to look see if the sensor can be accessed from the top. It can. Not sure how long it will stay in position though. Bloody Irmscher rubbish. ;D
....and can we have some more day light in the evenings please, this is bloody ridiculous. :(
While you were doing that, I got some foreigners to wash mine. ;D
With all that hooky money from stolen wheels? A full vallet next time, tight arse!
plym ian
Changed antifreeze before it gets too cold to work on car :)
yesterday changed the brake discs, pads, read drum pads and other bits including brake hydraulic for clit with originals.. cost more than 200£ (with %10 discount).. clearly thats a robbery  :o :o   :(
4x4
Fitted my response team number to truck today
plym ian
MOT pass on the 3.2 with no advisories.
New rear shocks and Cat back exhaust system on Mrs VXL's Alhambra (Not that I did much, just assisted my friendly garage!)
Oil and filter on the 2.6
So that was my day off work!
bertie1.8vectra
Fitted new cam cover gasket... cleaned egr out.... changed coolant and flushed heater matrix.... All in all a produtive day off, i hope!!! ;D ;D
Now to buy shares in BP!!!!!!!!!
danzigfan
Changed right vertical bush on lower suspension arm, oil filter and oil on old lady. Booked for full geo setup tomorrow. Still going strong after 275.000km :y
chrisgixer
Should really be in pairs danzigfan. Just so your aware :)
Front discs and pads on a members car, along with some interior remodelling :)
Need to visit the breakers tomorrow to acquire a hedgehog to fix the blower in the 2.2...
A bit of welding, rear caliper change and a check over for water leaks on a members car.
Quote from: Marks DTM Calib on 16 November 2014, 19:58:23
Has he finally vented the rear brakes on that poor car... ;D
the alarming man
Quote from: plym ian on 14 November 2014, 18:02:35
Quote from: 4x4 on 14 November 2014, 17:46:17
whats that for ???
4x4 response help out in times of flood,snow......all voluntary but worth while
http://www.4x4response.info/
Quote from: Taxi Al on 16 November 2014, 20:17:38
No, of course not. Why do you think vented are needed  :-\
