Quote from: Taxi Al on 05 April 2015, 16:22:14
Near side rear wheel bearing :-\
That could be a job for High Wycombe!
Quote from: Andy H on 05 April 2015, 19:03:26
Quote from: TheBoy on 05 April 2015, 18:26:42
Changed the oil on TBE  :-[
How many miles since the last change?
Not entirely sure, but it was pretty dark.  If I had to guess, I'd say about 10k  :-[
Put a couple of albums in that I hadn't listened to for an age and took it for a couple of hour long blasts...
Have to say, in 4x4 guise, the Insignia seems to relish being driven, with a sweet spot between 2300 and 3000 rpm... it might have half the power of the VXR, but it's just as capable through the twisties 8)
Timetraveller5
Did not do it myself, but had a new waterpump fitted & a new belt :)
Cheers Martin
chrisgixer
Quote from: Nick W on 05 April 2015, 17:07:49
I probably need to check it is actually the bearing, and not tyre/dif/drive shaft related. But it if you don't mind chucking the tools in the boot...? :)
EMD
FL car are the bestest ever  ::) Superior drive , a/c dont seem very cool so shall have to probe that . Maybe some new tyres on the front soon but other than that just driven it loads  :y
How come no door card wear  ???
Omegatitis
chrisgixer
Cut the grass, emptied the shed, put the garden furniture out, weeded the beds....
....oh, and changed the oil. After 11,500 miles. :-[  whoops.
Car showing 22.5 degrees outside temp. though which helps. Every bugger and their dog is out cutting the grass. ....wheres that bloke that works nights ? ;D
plym ian
Out for a drive today, cars had a slight misfire for a while but today it's got really bad and eml came on. Code was missing fire pot 4 got a feeling it's the hg as it's the same symptoms as when my 2.0 went :-\
Quote from: plym ian on 06 April 2015, 17:57:44
Always worth checking coil pack first :y
Time for a V6 then Ian.  :y
Lagondanet
Quote from: chrisgixer on 06 April 2015, 17:15:22
Are you saying I should change my oil then?
chrisgixer
Quote from: Lagondanet on 06 April 2015, 18:18:24
I look to change mine every 5k. ...failed, obviously.
Crazycarzowner
Light bulb changed in SWMBO's fiesta.  :)
