Author Topic: So what have you done to your car today?  (Read 5879712 times)
Rangie and 84 Guests are viewing this topic.
Raeturbo
  • South Wales
    • TouregR5Mitsi Evo2. XJ8
« Reply #24690 on: 13 January 2023, 23:48:36 »
Well now that we can see what’s under it………..😵‍💫🤭😂😂😂
Laying a rubber road.
countrywoman
  • worcestershire
    • skoda yeti
« Reply #24691 on: 15 January 2023, 10:54:46 »
Just bought a stainless oil cooler from a Vectra 2.5 v6 for the Omega engine off the bay, £146 !!!! But how often do you see one?
ronnyd
  • Bury St Edmunds Suffolk
    • Vectra 1.8 SRI Silver
« Reply #24692 on: 15 January 2023, 12:47:18 »
Dry and bright here so removed filthy mats and vacuumed all the crud that was under 'em. then it started to rain,  ::) Thankfully very brief so carried on and cleaned mats. All ok except drivers which is very stained. Why the hell did i get LIGHT grey ones.  ::) Quite nice and bracing out this morning.
Migv6 le Frog Fan
  • Essex / Suffolk border.
    • 3.2 Elite. Nissan Leaf.
« Reply #24693 on: 15 January 2023, 16:26:54 »
Checked and topped up fluids on both. Removed o/s headlight from Omega. Will take it to work tonight and polish the lens and fit a new HID bulb.
« Reply #24694 on: 15 January 2023, 17:18:52 »
I topped up her screen wash with as much -20C as I could get in, seeing as what's in there was 50:50 mix from -10C stuff (I thought it was -20C stuff), as its gonna get a bit nippy this week.
Also did all the other fluid levels on hers, managed to get my fingers in the right place to disable the stupid stop-start wank, fitted the OS side cargo net, and finally found the missing passenger compartment fusebox I'm struggle to find where the manual said it was (because it was on the other side)
Not touched mine at all ;D
Raeturbo
  • South Wales
« Reply #24695 on: 15 January 2023, 19:59:50 »
Not touched my Omega for ages except to jumpstart it after a month. It’s indestructible 😎
    • 530D M Sport, 330i Coupe
« Reply #24696 on: 15 January 2023, 20:19:04 »
Removed the side indicator repeater on the 530D, tested the feed to it, attempted to dry the sealed LED unit to revive it. No good, ordered a new one (Mine has the park assist sensor in it so typically the unit with the hole in the housing for this is three times more expensive than the standard one :( ) Ordered new genuine unit, once fitted I think a session with a dremel on the old unit will follow to see if a repair can be made  :-\
« Reply #24697 on: 16 January 2023, 07:33:20 »
Pulled the head off the Neighbours sons boyfriends 1.0 Corsa.
Its been worked on before and clealry not well, sealant insetad of gasket on the water pump, sealant all around the timing cover, broken drain tap on the rad.
« Reply #24698 on: 16 January 2023, 18:05:13 »
sons boyfriends
Now I dont mean to stereotype, but that ususally always means the car is utterly fooked.
Rangie
  • Online Online
  • Lincolnshire
    • RRS TDV8 Yaris Cross
« Reply #24699 on: 16 January 2023, 18:23:36 »
Drove the RR to Peterborough & bought SWMBO a new MX5 for her birthday, she's always wanted one.
« Reply #24700 on: 16 January 2023, 18:29:23 »
sons boyfriends
No need to stereotype. Judging by the guys in my team at work, anything owned by a Gen Z'er will be "utterly fooked". ::)
I do try to instil the need for basic maintenance, or even checking things like tyre pressures, but to no avail.
Migv6 le Frog Fan
« Reply #24701 on: 16 January 2023, 18:33:40 »
I have at last got my son to check his tyre pressures, and possibly fluids every couple of weeks or so.
He is 38.  ;D
I was helping my Dad bleed brakes when I was 10 years old. And when I broke the gearbox on my first car (Viva) he said " theres a spare gearbox in the garden and spanners in the shed, you will work it out."  ;D
« Reply #24702 on: 16 January 2023, 18:46:59 »
My Audi has traction control apparently. It flashes a little yellow light on the dash when the wheels are spinning,  ....
I have the same problem in my 84bhp turbo'd Smart For2!  ::) But only ever at one particular junction when wet!  ;D
« Reply #24703 on: 16 January 2023, 19:17:51 »
sons boyfriends
Yes, now you mention it....
My bestie mate's neighbours son got a brand spanker Beemer on some lease scheme, but kept driving it with a dash full of warning lights until it expired when it was about 18 months old.  AA towed it back and dumped it on the verge outside the house, and that was where it remained because, being a millennial, he was unable to pick up a phone and talk to a garage, and there were no apps for "I've Donald ducked my car".  2.5yrs later when the 4yr lease finished, it was towed away by lease company who fined the lad heavily for the state it was in - non runner, 4 flat tyres, trees growing out of the scuttle.
    • Grandland 1.6 diesel
« Reply #24704 on: 16 January 2023, 20:50:05 »
New new or used new? Don't tell me you bought some VAT Mick?
Diesel till I die
