Booked in at Vauxhall! and More................
Started by Wayne, 01 October 2007, 17:17:35
Wayne
#76
£5  ??????????????  >:(
Aaarrgghhhhhhhhhhhhh
all i need doing on my car now is the "checkstrap" and them im a HAPPY bunny!  :y
I did buy some oil today, but your all gonna shout at me when i tell you what i paid for it!
all im going to say is "Castrol Edge 0w/30"  x  6 litres   ::)
and YES its the correct oil coz i checked  ;D
Retail is £81 !!!!    i paid  £55 for cash
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_199423_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_77303_crumb__parentcategoryrn_77303
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_183645_langId_-1_CarSelectorCatalogId__CarSelectorGroupId__varient__categoryId_77303_crumb__parentcategoryrn_77303
Quote£5  ??????????????  >:(
Probably too thin. Stick to Vx semi @ £30 for 20l
Wayne
i double checked matey
went to the Castrol website and it asks you to input your car details
they said best oil for my car is 0w/30
check it out
go here http://www.castrol.com/castrol/productdetailmin.do?categoryId=9014073&contentId=7027066
then go to bottom left where it says "which oil do i use"
you can then choose Vauxhall Omega 2.5 v6
it states the best oil is 0w/30, and then second is Magnatec 10w/40
so im sure Castrol wouldnt get themselves in trouble by selling me the wrong oil  :o
Quotethe repair kit is about a fiver...... continued.........
39. Install door and attaching parts as mentioned above, in
   reversed order
40. Install outside mirror
    - see working procedure "Replace Outside Mirror", unit "R",
    Service Instruction Omega-B.
41. Install loudspeaker
    - see working procedure "Loudspeaker - Front door, Remove and
    Install", unit "R", Service Instruction Omega-B.
42. Install inner panelling - front door
    - see working procedure "Inner panelling – front door, Remove
    and Install", unit "C", Service Instruction Omega-B.
43. Connect battery.
44. Program volatile memories.
Parts:                                   Part-No.:       Catalog.-No.:
Possibility I:
Omega-B:
2 reinforcement plates                   09 195 961      90 97 309
2 Fastening screws                       13 104 167      20 03 001
Vectra-B:
Possibility II:
Omega-B:
1 front door stop mounting bracket,      90 458 147      90 97 293
 left side
1 front door stop mounting bracket,      90 458 148      90 97 294
 right side
Possibility III:
Vectra-B:
1 front door stop mounting bracket,      90 507 501      90 01 077
 left side
1 front door stop mounting bracket,      90 507 502      90 01 076
 right side
Labour Times:                            TC:          Hours:
T 8 129 10    Repair with                92           0.6 (Omega-B)
             reinforcement                           0.9 (Vectra-B)
             plates without
             side bag
T 8 129 11    Repair with                92           0.7 (Omega-B)
             reinforcement                           1.1 (Vectra-B)
             plates with
             side bag
T 8 129 12    Repair with                92           3.2 (Omega-B)
             bracket front                           3.2 (Vectra-B)
             check link
             without side bag
T 8 129 13    Repair with                92           3.4 (Omega-B)
             bracket front                           3.4 (Vectra-B)
             check link
             with side bag
T 8 129 14    Painting and               92           1.3 (Omega-B)
             finishing work                          1.3 (Vectra-B)
The costs for this repair will be covered for vehicles not older than
3 years and a mileage lower than 100.000 km.
The regular warranty procedure should be used for claiming Set-up-time....
Quotei double checked matey
check it out
I bet every car you enter built in last 15 years it will say the same. Doesn't mean they are right.  I certainly would not be using it in mine.
I would strongle recommend to spend the extra money it costs on more regular changes ;)
Wayne
FAIR COMMENT MATEY  :y
but im gonna put it in and before i do, im gonna see where i stand IF it ruins me car
be interested to see what Castrol say if i ring their "press office" and ask them "are you sure its OK for my car" !!!
But this is what Vx quoted for:-
This is an extract from Vx TIS system
Notes – not all drawings are reproduced. Some info refers to Vectra B
Extract starts here..............
Field Remedy: 1291
Subject:      Front doors-Check link - pulls out of door panel
Models:      Engines:      Option:
Omega-B 1996...2000,Vectra-B 1996...2002      All,All
Complaint:      Check link of front door cracked.
Cause:      Due to excess bending tension front check link bracket cracks.
Production:      Omega-B: Modified check links have been introduced in production as of the following VIN: W0L0VBP69Y1176008 (Rüsselsheim). Vectra-B: None.
Remedy:
There are 3 possibilities:
I:   Installation of two reinforcement plates, only in case of
     cracks and WITHOUT strong deformation of the door body.
II:   Omega-B: Welding the check link - front door mounting bracket and
     installation of two reinforcement plates in case of cracks
     and strong deformation of the door body.
III:  Vectra-B: Welding the check link - front door mounting bracket
     WITHOUT installation of two reinforcement plates in case of cracks
Working Procedure:
Possibility I (Omega-B and Vectra-B):
1. Disconnect battery.
2. Remove inner panelling - front door
    and Install", unit "C", of the corresponding Service Instruction.
3. Remove loudspeaker
    Install", unit "R", of the corresponding Service Instruction.
4. Separate wiring harness connector of front door.
5. Remove check link - front door.
6. Shorten and bevel the outer reinforcement plate on both sides by
   7.5 mm (Fig. I).
7. Paint the reinforcement plates in the colour of the car.
8. Set original inner reinforcement plate onto the check link - front
   door and insert into front door.
9. Install the modified outer reinforcement plate to the check link -
   front door with new fixing screws – use locking compound.
10. Install wiring harness connector of front door.
11. Install loudspeakers
    Install", unit "R", of the corresponding Service Instructions.
12. Install inner panelling – front door
13. Connect battery.
14. Program volatile memories.
Possibility II (Omega-B):
1. Remove inner panelling - front door
    - see working procedure, "Inner panelling – front door, Remove
2. Remove loudspeaker
3. Remove outside mirror
4. Open sash window.
5. Partially loosen front door window guide seal.
6. Remove guide rail of front door window.
7. Close sash window.
8. Disconnect battery.
9. Remove front door
    - see working procedure "Front or rear door, Remove and
    Install", unit "A", Service Instruction Omega-B.
10. Set door to installation carrier.
11. Disconnect front door wiring harness up to loudspeaker area.
12. Remove check link - front door.
13. Remove front door gum seal in the front area.
14. Punch the welding points of the mounting bracket of the check
   link - front door (8 per door).
15. Drill through the welding points with a welding point drill
   (pic. II).
16. Remove drill chips completely.
17. Remove the check link - front door mounting bracket with a
   chisel and a drift punch from the front door.
18. Take off the check link - front door mounting bracket through
   the loudspeaker aperture.
19. Perform cleaning work.
20. Insert new check link - front door mounting bracket through the
   loudspeaker aperture (pic. III).
21. Fix the check link - front door mounting bracket with two drift
   punches.
22. Mark the welding points by drill holes in the new check link -
   front door mounting bracket (pic. IV).
23. Take off the check link - front door mounting bracket.
24. Grind the welding areas of the check link - front door mounting
   bracket with an angle grinder.
25. Insert the check link - front door mounting bracket and center
   it (pic. V). Centre the oval door aperture to the exterior sheet.
   Mark rectangular check link - front door aperture to the check
   link - front door mounting bracket, centred 6 mm.
26. Fix the check link - front door mounting bracket (2 fixing
   screws M5).
27. Protect water-repellent foil and inside of door from sparks.
28. Weld the check link - front door on mounting bracket.
29. Remove fixing screws M5.
30. Grind welding points with angle grinder.
31. Perform cleaning work.
32. Apply zinc spray paint to welding area.
33. Shorten the original outer reinforcement plate on both sides
   (see pic. I).
34. Paint the door with reinforcement plates.
35. Set modified inner reinforcement plate onto the check link -
   front door and insert into front door.
36. Install the outer reinforcement plate to the check link - front
   door with old fixing screws – use locking compound.
37. Apply cavity protection in the repair area.
38. Lay and fix front door wiring harness.
My replies are obviously arse about face but you get the idea
QuoteFAIR COMMENT MATEY  :y
It won't ruin the car. Definately not. Castrol GTX - probably the crappest oil out there - won't ruin it.
As said, that £50 is 4 oil changes using Vx semi (at TC prices), and I can assure you which will be better for your engine!
Wayne
i know what your saying, just wanted to see what its like, next time i will use cheaper stuff if i notice any crap with me car
Quotei know what your saying, just wanted to see what its like, next time i will use cheaper stuff if i notice any crap with me car
You will not notice any difference.  Possibly the thinner oil may burn or leak easier.
Taxi_Driver
Agree with TB..... :y
New engines.....thin oil prob ok......old engines stick to the thicker stuff  :y
My 2.2 on 105k now likes the semi synth  :y
Wayne
#88
i bought the stuff now, and im awaiting a call from Castrol tomorrow
0w/30 is there recommendation, lets see what their press office say
will also speak to some mechanics tomorrow that i know
after all, they SHOULD know what they are talking about, and so should Castrol
my oil gets changed every 5000 miles anyway
i take it that at my next oil change its OK to go back to 10w/40 then?
wasnt sure if you could "mix n match" after you have had a different "viscosity" in ya car?
interesting viewing below
(i await all the sarcasm)
http://www.youtube.com/watch?v=15v5VsQ98hQ
http://www.youtube.com/watch?v=zFmJh9l4MXw
Taxi_Driver
Quotei bought the stuff now, and im awaiting a call from Castrol tomorrow
No sarcasm m8  :y........ordinary semi synth,,,,cheap as chips with TC is the way to go  :y
Just my opinon tho  :y
