Author Topic: DASHBOARD POWER FAILURE  (Read 1205 times)
FRE07962128
« on: 17 April 2008, 12:56:35 »
I am a desperate damsel in distress, so can someone help me please?
I removed the dashboard on my Omega to replace a light bulb.  Refitted it but now none of the clocks work, the central consul is dead, and only the indicators on the dashboard are working along with the temp. fuel, & handbrake warning lights flashing!  I have refitted the dashboard four times, checking the terminals, but still no joy!
What have I done wrong please?
A tearful Lizzie Zoom  :'( :'( :'( :'( :'(
Re: DASHBOARD POWER FAILURE
« Reply #1 on: 17 April 2008, 13:36:26 »
sounds like something hasnt been plugged back in. :-/
« Reply #2 on: 17 April 2008, 14:09:24 »
Ive done similar myself today,
Dash out to change 3 illumination bulbs (only 1 gone)
Put it back together, and no lights!
Took it apart, reseated bulbs, put it back together, all happy.
You have pushed the dash far enough back home havent you?
« Reply #3 on: 17 April 2008, 14:10:09 »
1) makes sure the instrument panel is fully home
2) Check the fuses (cant remember which but F14 or 15 rings a bell)
f13platform
  • birmingham
  • f13..
« Reply #4 on: 17 April 2008, 14:15:49 »
u have to push it back and put the bolt back on
than try it ...
i hope u didnt damge that  bule paper in back of the speedo meter
make sure the blub holder are in right place
they conect with the blue paepar :y
rickyboy
  • Glasgow
« Reply #5 on: 17 April 2008, 15:06:50 »
Just changed the fuse an hour ago.  As Mark said F15 will make the dash lights go out, so check it hasn't blown.  I suspect the clocks aren't fully home.   :y
FRE07962128
« Reply #6 on: 17 April 2008, 19:21:37 »
Thanks all!
I have discovered a fuse that covers all the dash and consul had blown!  All ok now.  A very relieved Lizzie Zoom :D :D :D :D :y :y
