Pages: [1] 2 3  All   Go Down
Author Topic: Help please  (Read 4638 times)
bighed
  • Shropshire
Help please
« on: 10 November 2008, 16:06:13 »
Hi guys, I have Just got into my mig after about half an hour of being away from it and its now shaking heavily on tickover and sounds like its misfiring under revs. Any ideas? Sparkplugs have not long been done. Could it be a faulty lead?
Just noticed my avatar has gone funny.. Was ok yesterday. (normal size) Any ideas :-[ :-?
« Last Edit: 10 November 2008, 16:09:43 by bighed »
Re: Help please
« Reply #1 on: 10 November 2008, 16:10:14 »
I personally would check the leads for soundness (has it been in heavy rain today?), but many on here will say straight away "crank sensor" which when it suddenly goes causes the symptons you describe. :y
Have you done a paperclip test? I ask that not knowing the model you have which may rule that out in that manner.  Please place your vehicle details into the profile:)
« Last Edit: 10 November 2008, 16:11:40 by Lizzie_Zoom »
bighed
  • Shropshire
Re: Help please
« Reply #2 on: 10 November 2008, 16:13:48 »
My apologies. Its a 99 2.5 V6 CDX. Not done paperclip test as no eml light has come on. Will go do it now.
« Last Edit: 10 November 2008, 16:15:33 by bighed »
bighed
  • Shropshire
Re: Help please
« Reply #3 on: 10 November 2008, 16:40:43 »
AA man has just been and says try some new ignition leads, but could be coil pack. Anyway of testing this as new leads from vaux aint cheap
Also will there be a fault code if no eml light has come on?
Re: Help please
« Reply #4 on: 10 November 2008, 16:51:49 »
Not every code causes the light to come on.
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
bighed
  • Shropshire
Re: Help please
« Reply #5 on: 10 November 2008, 17:06:39 »
Just tested and its given me code 73. Mass air flow sensor voltage low????  :-/
bighed
  • Shropshire
Re: Help please
« Reply #6 on: 10 November 2008, 17:55:19 »
Will it still be ok to drive on short trips as got to take mrs n little un to see midwife tomorrow afternoon.
Hospital is about 3 miles away
« Last Edit: 10 November 2008, 17:55:49 by bighed »
Re: Help please
« Reply #7 on: 10 November 2008, 18:19:44 »
Most likely an air leak then.
Re: Help please
« Reply #8 on: 10 November 2008, 18:20:09 »
Wouldn't keep using it for too long without resolving it
bighed
  • Shropshire
Re: Help please
« Reply #9 on: 10 November 2008, 18:40:15 »
Unplugged mass air (if it was the right one I unplugged) and the engine almost died then picked up but revs sounded lower. Air leak?? would a blow in the exhaust do this? Just pulled a sparkplug out and it runs exactly the same??  :-/
« Last Edit: 10 November 2008, 18:41:54 by bighed »
bighed
  • Shropshire
Re: Help please
« Reply #10 on: 10 November 2008, 19:10:49 »
As above, exhaust blows (sounds tappy on start up) would this effect it in any way?  :-/
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Help please
« Reply #11 on: 10 November 2008, 19:37:56 »
Wouldn't have thought a blowing exhaust would have caused your problem.
Check for air leaks like already suggested :y
Re: Help please
« Reply #12 on: 10 November 2008, 19:58:18 »
Could do, depending on how bad, and where.
bighed
  • Shropshire
Re: Help please
« Reply #13 on: 10 November 2008, 20:14:48 »
It sounds like just behind and down from top plenum area. Would that be manifold? Bet thats a right pain in backside to change??
bighed
  • Shropshire
Re: Help please
« Reply #14 on: 10 November 2008, 20:35:13 »
Would exhaust blowing bring up code 73???
Pages: [1] 2 3  All   Go Up
