Author Topic: HELP ME SOMEONE!!!  (Read 2989 times)
gabby48
  • nottingham
HELP ME SOMEONE!!!
« on: 13 July 2009, 21:54:45 »
This car is driving me nuts!!   >:(replaced the o2 and maf sensors.  Plugs.  blooming thing is still chugging.  had the engine management light turned off after each time and still it comes back!!  ::)
I really love this car but if it continues i will have no choice but to give up with it. :-[ #  I dont really want to see it go.
If anyone can help with this continuing problem i would really appreciate it.  thanks  :)
bluehawk
Re: HELP ME SOMEONE!!!
« Reply #1 on: 13 July 2009, 21:59:31 »
what fault codes have you had on it , you need some one to read them it could be anything from a crank sensor upwards. but to save you money and time get the codes read and post them up here. there are plenty of good mechanics who are used to omegas on here that will give you a good idea of what it is
« Reply #2 on: 13 July 2009, 21:59:51 »
Little more info would help....
what are the exact sympoms,
do you know what codes have been previously stored.
when did it start happening....after any particular work
is it worse after heavy rain?
Didn't Mark do something for you a few months back?
« Last Edit: 13 July 2009, 22:00:30 by jimbob »
Pedro
« Reply #3 on: 13 July 2009, 22:00:30 »
Have you had it checked with Tech 2?
Problem is, going to a local stealer, paying £75+ for the use of their Tech 2 and then having summat replaced and charged for and still the problem doesn't go away is a nightmare! (And it does happen).
If someone local to you has one though..........
« Reply #4 on: 13 July 2009, 22:02:00 »
Bit more info would help mate.
alexandjen
  • Sittingbourne, Kent
  • The Silver Surfer
« Reply #5 on: 13 July 2009, 22:07:50 »
Mr DTM lives just down the road :y
Trade club card holder
Code scanner available
« Reply #6 on: 13 July 2009, 22:08:41 »
and I'm sure had a look last time  :-/
« Reply #7 on: 13 July 2009, 22:21:19 »
see pedal trick
free diagnostic for engine ecu only  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
post the codes...............or visit Mark :)
« Reply #8 on: 13 July 2009, 22:23:21 »
see pedal trick
2.2 so no code reading tricks  :'(
« Reply #9 on: 13 July 2009, 22:41:03 »
see pedal trick
oh pants, sure i read it as 3.2, sorry off to spec savers.  seem to struggle with numbers of late  :-/ cocked up a crank sensor thread the other day. :-[
« Last Edit: 13 July 2009, 22:41:44 by chrisgixer »
gabby48
  • nottingham
« Reply #10 on: 13 July 2009, 23:23:16 »
not showing any codes when checked now, but engine light keeps coming on.
had problem for awhile.  was looked at by dtm. changed the maf sensor solved it for awhile then it came back.  after couple of mile light comes back again.
funny enough it does get worse after heavy rain :-?
it chugs and bangs and shakes when started has no power at all. even a pushbike overtook me the other day!  it was going so slow.  Then it willsuddenly find the power and shoot off.
getting really stressed with it.
another weird thing is the radio was off for awhile due to stupid garage disconnecting the battery.  it seemed a bit improved.  but as soon as it was back on again the problem seemed worsened.
« Reply #11 on: 14 July 2009, 07:07:22 »
several 2.2's have had an issue (esp if parked slightly downhill) where water escapes from the scuttle drian, drips onto the engine, and finds it way into the spark plugs.
I dont know if you have any tools or not, if you have torx bits, it will take you 2 mins to check....
unplug the connector from the far end of the engine, slide the black ecotec cover off, then 2 bolts to remove the coil pack, lift this out and check for water in the plug wells.
gabby48
  • nottingham
« Reply #12 on: 14 July 2009, 10:11:33 »
my son in law noticed  water in there when he changed the plugs for me.  how can i stop this and is this the route of the problem?
thanks  ;D
« Reply #13 on: 14 July 2009, 12:07:21 »
In our case, water was escaping where the large and small scuttle pieces met, filling this join with silicone worked for us.
others have been the result of a poor windscreen seal.
keep them dry in the meantime, park facing uphill, and you may find it helps.
wet plugs will certainly cause these issues, and cause early death of the coil pack as well  :'(
« Last Edit: 14 July 2009, 12:07:58 by jimbob »
gabby48
  • nottingham
« Reply #14 on: 15 July 2009, 11:28:14 »
ok will get him to have a look. thanks everyone for all your help.
 im determined to sort this car out cause i really do love it.....when it runs nicely :-[
