Author Topic: V6 Vs 4Cyl Air Conditioning System  (Read 1063 times)
megaOmega
« on: 23 July 2009, 16:20:21 »
Two people i know have omegas of around the same age, one has a 2.2 and the other has a 3.0 elite, the elite has significantly better air conditioning even though the 2.2 had just had a re-gas and the sysyem is fine!
are there different components used eg, compressor / rad?
could someone explain this!
thanks
Re: V6 Vs 4Cyl Air Conditioning System
« Reply #1 on: 23 July 2009, 16:21:36 »
Think they differ with age and use....
we have 2 x 3.0's
one is significantly cooler than the other.
« Reply #2 on: 23 July 2009, 16:22:48 »
system is basically the same, my 2.2 has better aircon than our 3.0 Elite Estate, but that has had a new condensor and dryer.
As Jimbob said, its all based on age and servicing.
pauldmackay
« Reply #3 on: 23 July 2009, 18:16:36 »
Wouldn't have thought it would have made any difference.
As long as the air con system is serviced/re-gased every couple of years to keep things running as they should the cooling temp should be fine.
Only way to check properly is touse a temp gauage at the cooling vents.
