Author Topic: New cruise stalk on 2.5 td ?  (Read 3647 times)
Stevie-blunder
  • Wolverhampton
« on: 10 September 2009, 18:37:48 »
Hi all, fitted a cruise stalk on my tractor today but doesn't work  :( ! Have I got to install a fuse or relay somewhere? Or is it something else?
Thanks.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: New cruise stalk on 2.5 td ?
« Reply #1 on: 10 September 2009, 18:45:03 »
It's plug & play provided the stalk was a 2 wire one
Mine worked immediately
Stevie-blunder
  • Wolverhampton
« Reply #2 on: 10 September 2009, 18:49:59 »
There's a plug on it with 4 wires that goes into a lead on the column with 2 wires.
charlie
  • sunderland
« Reply #3 on: 10 September 2009, 18:55:23 »
its a two wire one for the 2.5 td part no 9181012 .      not part no 9181014
Stevie-blunder
  • Wolverhampton
« Reply #4 on: 10 September 2009, 19:04:00 »
This one is part no. 9181011. Could I re route the wires?
« Reply #5 on: 10 September 2009, 19:15:27 »
sounds like yuo have one based on switches....think td uses resistance, and the 2 are very different.
smokingomega
  • Leeds
« Reply #6 on: 10 September 2009, 19:31:56 »
Mine has 2 wires also. I got the 4 wire one to start with but wouldn`t fit so just bought the 2 wire one
Stevie-blunder
  • Wolverhampton
« Reply #7 on: 10 September 2009, 19:35:33 »
OOPS !! anyone got one for sale or swap?  :y
« Reply #8 on: 10 September 2009, 19:48:30 »
TD needs the 2 wire one ending on 012, not the 4 wire one ending in 011.
No easy way to bodge wrong one one
Turk
  • Llanelli, Wales
    • 2.5td, H-D XL1200
« Reply #9 on: 11 September 2009, 00:20:45 »
Yep, mine too  :y
« Reply #10 on: 11 September 2009, 09:17:08 »
Yep, mine too  :y
All the TDs do if you fit the right stalk ;)
Also, not mentioned in manual, the R button does NOT reduce speed on the TD, unlike all the others
flymofred
  • nr. Tunbridge Wells (Royal)
    • (53) 2.6 Elite Estate
« Reply #11 on: 11 September 2009, 10:53:09 »
glad to see this thread, but sorry you ended up with wrong one I need a new stalk for mine the headlamps keep going to main. Thanks for the part no. Vauxhall don't know which one it is, and insist there's number on the existing one ,there ain't. how much are these jobbies
martinH
MickAP
  • South Derbyshire
« Reply #12 on: 11 September 2009, 11:08:59 »
martinH
I paid around £36 +vat......from the dealer, and yes it's defo two wire job a straight swop and it worked.
They do come up secondhand on ebay sometimes but it's best to get new as s/h are most likely worn anyway, and they want too much for them.
Mick
« Last Edit: 11 September 2009, 11:09:38 by MickAP »
Omegatoy
  • UK
« Reply #13 on: 11 September 2009, 18:11:33 »
Yep, mine too  :y
r button is resume surely????? thats how i use it anyway, when cruise has been cancelled by brakes or clutch just tap r button and it resumes the previously set speed??? :y
« Reply #14 on: 11 September 2009, 18:41:59 »
Yep, mine too  :y
on petrol its resume, if no cruise active, if it is, then its 1mph reduction or maybe 2 :-/
