Author Topic: Diff oil  (Read 1115 times)
mathewst
  • Split, Croatia
    • v40
Diff oil
« on: 19 November 2009, 16:41:52 »
Simple question, does this need changing?
Think it has never been changed.
I'm not sure did I write correctly I mean diff as the part on the rear axle where propshaft goes in
Re: Diff oil
« Reply #1 on: 19 November 2009, 16:58:01 »
Re: Diff oil
« Reply #2 on: 19 November 2009, 16:58:17 »
There's no easy way to drain it other than to take off the backplate. If it's not an LSD then I'd say leave it be.
You might be able to get it nice and hot and then use an oil extractor in the level plug perhaps?
Re: Diff oil
« Reply #3 on: 19 November 2009, 22:09:06 »
i just topped mine up. It dunarf penanink. There is a guide if that helps. Wouldnt worry too much unless its high miles or done a lot of towing. Or if the areas is wet with oil maybe the prop seal is past it, just top it up to the level hole i guess?
« Last Edit: 19 November 2009, 22:10:25 by chrisgixer »
Welung666
Re: Diff oil
« Reply #4 on: 19 November 2009, 22:16:16 »
It's hypoid, stinks like cat pee  ;D ;D ;D
