Author Topic: auto question  (Read 1417 times)
doog
  • Alloa Central Scotland
auto question
« on: 08 December 2009, 13:21:59 »
my omega auto  drives like a car with a slipping clutch  revs high before moving etc   then comes up on display " automatic gearbox"
I bought the car with a gearbox problem but i would like to find out what ithe issue is before i replace the box
oh and no stored fault codes
any input wouold be great :y
Doug
me at kick boxing
Re: auto question
« Reply #1 on: 08 December 2009, 13:23:05 »
1st call is to check the fluid level, may just be low.
Presume you have just cehcked for engine codes uysing paperclip etc?
gearbox has its own ecu a good code reader can interrogate  :y
« Last Edit: 08 December 2009, 13:23:42 by jimbob »
Richard A
  • Aldridge, West Midlands
Re: auto question
« Reply #2 on: 08 December 2009, 17:39:50 »
Would be good to have car details, but yes, check fluid level and colour, if ok, need to know in which gear does the engine rev (flare), the gear changes are controlled by 'solenoids' which can be changed, (£80) members may help.
Regards
Richard A
richard a
doog
Re: auto question
« Reply #3 on: 08 December 2009, 18:12:01 »
its a 99 (t) 2.5 v6 auto elite
no fault codes stored (checked with "My Naff Code Reader")
Doug
« Last Edit: 08 December 2009, 18:12:54 by doog »
me at kick boxing
Richard A
Re: auto question
« Reply #4 on: 08 December 2009, 19:19:47 »
Mileage also helps, the 'dealers' said the 'autobox fluid' was sealed for life, bulls---, so people never checked it's condition or level, worth a go as it will cost very little.
regards
richard a
richard a
davethediver
  • Blackburn, Lancs.
Re: auto question
« Reply #5 on: 08 December 2009, 19:25:23 »
ATF should be changed every 60K IIRC :)
P.A. Caron de Beaumarchais
