Pages: 1 2 3 4 5 [6] 7 8   Go Down
Author Topic: no drive or reverse :( help needed urgent  (Read 14149 times)
steve78
Re: no drive or reverse :( help needed urgent
« Reply #75 on: 11 January 2010, 19:26:43 »
[img][/img]
steve78
« Reply #76 on: 11 January 2010, 20:55:42 »
can anyone shed some light on my problem please!!!!! or have i bored you all lol
sexydaz
« Reply #77 on: 11 January 2010, 21:12:41 »
dont know if its the same but on my 2.2 if you stand at the front of car (underneath obviously)and look at the n/s about half way up the bell housing theres a hole in the block and there is the(flywheel)15mm socket on a flexi and extension 5 or 6 bolts and thats it,the haynes only goes to 1999 iirc and it does show a gromit at bottom to get to flywheel and a plate or gromit to allow you access to bolts but not on mine 2001 you really want to take box off with tc its a lot easier to fit tc to box rather than box to tc,if im wrong someone will correct  :y
steve78
« Reply #78 on: 11 January 2010, 21:24:11 »
ok so as for effort on taking the box out with the tc box attached its no different ? also is there anything i should be away wen taking it out like wires on top or a large amount of oil coming out as tc still in place, so far i have everything of apart from tc bolts, thanks steve
steve78
« Reply #79 on: 11 January 2010, 21:26:34 »
also the bellhousing is the mount on the end of the box near propshaft yes?
« Reply #80 on: 11 January 2010, 21:27:16 »
TC needs to come off with box, and its utterly critical that tc is inserted fully in box before refitting box
« Reply #81 on: 11 January 2010, 21:27:35 »
Yeh, only rtun the crank clockwise.....and when you re-fit the tc needs to go FULLY onto the box before fitting
steve78
« Reply #82 on: 11 January 2010, 21:31:53 »
ok got that . so why do some say undo tc bolts before taking out the box?
steve78
« Reply #83 on: 11 January 2010, 21:33:05 »
im sure i did turn it clock wise but if you dont what would the result be?
« Reply #84 on: 11 January 2010, 21:34:26 »
Practice for putting them back in ;D
Seriously, I find it easier, as you have drag of box to help undo them
« Reply #85 on: 11 January 2010, 21:35:20 »
Bellhousing is at the front :y
steve78
« Reply #86 on: 11 January 2010, 21:36:16 »
lol so basically its harder to pull the box of with out undoing the tc bolts
steve78
« Reply #87 on: 11 January 2010, 21:38:21 »
rob i think i may have undone the wrong bolts!!!! does the tc sit inside bellhousing then as i undone the bolts which was 13mm and 19mm going from starter motor all the way round!
« Last Edit: 11 January 2010, 21:41:58 by steveomega »
sexydaz
« Reply #88 on: 11 January 2010, 21:51:01 »
when you buy a new box it should come with the tc so basically drop yer box and you will see the tc bolted to your engine and hopefully all will come come to light of what peeps have been saying,carefull as you drop it for any plugs still connected and the breather on top(this is if you get the tc with your replacement box)the haynes tells you about and shows pics of the tc in the box and if irrc the mating surface of the tc to driveplate should be 15mm into the box from the bell housing face(god thats sad) ;D
« Reply #89 on: 11 January 2010, 22:10:36 »
You can remove the box without the torque convertor but the T/C MUST be removed and fully engaged within the bellhousing for re-fitting.
Pages: 1 2 3 4 5 [6] 7 8   Go Up
Page created in 0.013 seconds with 14 queries.
