Author Topic: ECU/Relay box removal  (Read 1442 times)
GaryBC
  • Egham, Surrey
« on: 01 February 2010, 16:46:17 »
I've got an ABS ECU change coming when the weather warms up!
To give myself a bit better access I want to pull the relay box to one side. I've had a quick look at it and it's not immediately obvious how it is attached.
Anyone got any pics, or a description please?
The car is a 2000(W) 2.5 petrol.
wanguttiz
  • Kaunas, Lithuania
Re: ECU/Relay box removal
« Reply #1 on: 01 February 2010, 20:37:34 »
I have another question regarding abs ecu: is it possible that the ecu has failed, cause i have no abs and tc, but still have speedo and servotronic working fine? I've bought the car already with that problem and have driven it for two years with no speedo or servotronic faults...
« Reply #2 on: 02 February 2010, 07:52:55 »
Sounds more like a different issue, duff sensor perhaps.
dragonlord
  • luton
« Reply #3 on: 02 February 2010, 22:22:22 »
got no pics but had to do this my self and this way is the easyest way i found
remove battery
completely remove fuse/ relay box
was held up fingering how to undue the 3 big round mulitplug thing
you know em when you get to them
you unduo em by unscrewing then the pull out
drain coolant and remove top radiator hose
not stictly nessersery but make it far easyer if you remove power steering reservoir as well
then for get try to undo the 6 torx screws on ecu yet
losen the two nut that hold the whole abs unit down
now you can lift the whole unit up by the brake lines
dont go mad pulling it just lift enough so a m8/ helper
ban then undo the 6screws
for that you need a extra long torx bit t20 if i remember right size
refit in reverse of above fill coolant
put some steering fluid in power steering reservoir
and dont for get to bleed power steering.
ie start car power stering will ushally make a right nose dont worry about noise
now with out moving/driving repeatedly go lock to lock on steering and it will shut up
recheck levil and top up if need be
then just check a day or so later after a drive in case
other way is become a contutionist with a fexable driver on them torx screws and some tape on end of torx bit
and a hole lot of swearing and tool trowing
and bloody knuckels
trust me the above is the easyest way by far
and i could do it now in about less that a couple of hours and 6 coffeys
for the price of the radiator top hose just get a new one while you are at as min was so stuck on i had to cut and it was buldging anyway.
GaryBC
  • Egham, Surrey
« Reply #4 on: 04 February 2010, 12:11:48 »
remove battery
and bloody knuckels
It's the fuse/relay box removal I can't figure out! Where are the attachment screws?
dragonlord
  • luton
« Reply #5 on: 04 February 2010, 14:12:45 »
try thing from memory
dont hold to it but if i remmember the top bit is cliped on
and the rest is screwed down
iv go to go out a bit later and check coolant leak so if know one else can post i have a look
dragonlord
  • luton
« Reply #6 on: 04 February 2010, 14:30:32 »
here just had a look
and remembered i dident need to take the whole lot out
you just need to pull bat ,remove small fuse thing with the large fuses in it that just clips slides on
if i remember rightly you have remove fuses and wireing with fuse holders before you can un clip box
the fuse holders  sort of slide/clip in to plastic tray
then i just removed that a hinged lid/cover of relays with the fuse box bit still atached as the plastic lid will un snap at the hinge
the hinge just clicks/snaps in
you see what i mean if you look
i also removed the ecu thing in main box that clips on
that just slides out
as that get some more wireing out of your way
just take your time it aint hard to figer out once you start pulling bits out
the only hard bit is getting the 6 torx screws in and out of the abs ecu
and if there s two of you and do like above that prity easy to do
it looks a lot worse than it is
« Last Edit: 04 February 2010, 14:38:51 by outlaw1234 »
« Reply #7 on: 04 February 2010, 14:41:13 »
