Author Topic: Engine coolant change/flush.  (Read 1143 times)
Mikes1670
  • Hull
« on: 04 May 2010, 09:27:55 »
Hi all, my mind has gone blank - I'm not a morning person! I am going to change my coolant from blue anti-freeze to Vauxhalls long life red anti-freeze. Can someone please direct me to the procedure on how to flush the coolant system. I understand that the V6 cannot be drained completely.
TIA.
Re: Engine coolant change/flush.
« Reply #1 on: 04 May 2010, 09:36:04 »
there are guides on this in the maint section, link to the index in my signature  :y
Mikes1670
  • Hull
« Reply #2 on: 04 May 2010, 09:42:05 »
Found it, cheers Jimbob - I had been looking in common issuess and FAQ's section!!
 :y :y :y
Hannah Judes Dad
    • the misses round the bend
« Reply #3 on: 04 May 2010, 09:48:33 »
First thing is to remove header tank cap then get under neath the car and open the drain bung at the bottom of the radiator (passenger side) to release the old coolant.Once you have deposited most of thie coolant on to your arm/driveway now is a good time to think about getting a drip tray!! Flush the system through several times with water to make sure as much of your old coolant is removed from the sytem.How many times have you wished for that drip tray? Once you are happy that the old coolant is out refit the drain bung you know the red one that came out in your hand with frustration after being stuck in for ages.Make up your coolant to the dilution that you want then add to the system via the header tank until you reach the required level on your header tank.Close the cap on the header tank,start the engine and put the heater up to hi.allow the engine to run for about five minutes then switch it off.Carefully remove the header tank cap and 'burp' the system for any airlocks then top up as required with coolant trying not to burn yourself in the process.I hope that helps.
Hannah Judes Dad
« Reply #4 on: 04 May 2010, 09:49:07 »
Must type quicker ! :D
