Author Topic: Petrol Leak  (Read 920 times)
coop1952
  • Woking
Petrol Leak
« on: 28 May 2010, 10:06:43 »
My 2002 V6 2.6 omega has got a petrol leak - well it certainly smells of it. When I put the heater on, the smell blows into the car. If I wind down the window when in traffic I can smell it as well. When I open the bonnet I can also smell it but its really difficult to accertain where its coming from. I've just had a service with new plugs which meant the plenum was removed and the 2 petrol pipes had to be disconnected. Are there 'o' rings in these connections to ensure a good seal?  Any other areas I could look at?
Re: Petrol Leak
« Reply #1 on: 28 May 2010, 10:17:16 »
There is an inspecton plate in the boot you can check for leaks.
http://www.omegaowners.com/forum/YaBB.pl?num=1186065848
they often corrode, which could cause your smell.
Omegafantasy
  • Oslo, Norway
Re: Petrol Leak
« Reply #2 on: 28 May 2010, 19:00:23 »
As I've had a few drops of fuel on my driveway plus smell from the car, I've checked mine too. Oh boy, it was rusted to pieces  ;D
It's about a year since I changed my fuel pump and the cover was tight (but somewhat rusty) then.
Thanks for reminding me of this  :)
By the way: is your covers made of plastic or metal? Mine is all metal, but the pictures in the mentioned thread looks like plastic.
1995 Omega 2.6 V6 Estate ("fresh" engine) Drives like a 2-litre. Grr! Gettin' dusted by a 1.8 auto Cav..
1991 Omega 3000-24v (major rust job)
(Interested in buying Vauxhall emblems/grille for my V6)
coop1952
  • Woking
Re: Petrol Leak
« Reply #3 on: 28 May 2010, 20:03:03 »
The smell is definitely coming from the engine bay. I wish it was from the back end of the car as I wouldn't have to drive along with the windows open to get rid of the smell. Could it be a problem with the injectors?
