Author Topic: Auto box sump plug  (Read 1685 times)
mahony
  • london
    • omega elite 3.0
Auto box sump plug
« on: 23 September 2010, 14:03:17 »
I have just tried to do a autobox oil change and found the filler plug rounded off,are they easier to get off with the sump dropped,maybe i will have to drill it out ? >:(
« Last Edit: 23 September 2010, 14:05:38 by mahony »
Re: Auto box sump plug
« Reply #1 on: 23 September 2010, 14:51:57 »
should be the same as an oil sump plug.
I swapped mine for the later torx with rubber washer style after the boss came detatched from the box to reduce stress
mahony
  • london
    • omega elite 3.0
« Reply #2 on: 23 September 2010, 15:08:25 »
It had a 13mm head on it.
« Last Edit: 23 September 2010, 15:10:29 by mahony »
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #3 on: 23 September 2010, 16:43:09 »
They can be incredibly tight, I dropped my sump first and even then it was a pain!! :(
mahony
  • london
    • omega elite 3.0
« Reply #4 on: 23 September 2010, 17:30:42 »
Anyone know the part number for the plug ?
TestOmega
  • Mississauga, Canada
  • Been helped, will help.
« Reply #5 on: 23 September 2010, 19:11:37 »
I am looking at the Cadillac Catera with many interchange-able part (if not all!) and it is as follows,
96041338      PLUG,A/TRNS FLUID PAN DRN(*KIT1)
Cheers.
!!!!!!!!!!!!!!!!!!  May I be blessed to give more than I receive  !!!!!!!!!!!!!!!!!!
« Reply #6 on: 23 September 2010, 19:16:11 »
From the EPC  ..
PLUG, DRAIN AND OIL FILLER, SIDE, AUTOMATIC TRANSMISSION    96041338
Exactly the same as the Catera it seems . :)
You'll also need :
SEAL, RING, 14.2 X 19.9, DRAIN PLUG, AUTOMATIC TRANSMISSION   11023582
HTH
« Last Edit: 23 September 2010, 19:17:39 by entwood »
mahony
  • london
    • omega elite 3.0
« Reply #7 on: 23 September 2010, 19:24:28 »
Thanks guys,i at least had some luck today in that i actually managed to change the oil filter and oil as previousley some numpty overtightened the canister and the whole lot spun around,had to use a chain wrench in the end ( metal band removal tool and pliers would not budge it ). :y
« Reply #8 on: 23 September 2010, 23:17:10 »
Full vx service history ?
mahony
  • london
    • omega elite 3.0
« Reply #9 on: 23 September 2010, 23:34:40 »
No not full vx history,some other numpty from local garage  :-X
