Author Topic: Can't Get My Headlight Bulbs Out!  (Read 1653 times)
car-nut
  • Kent Border, East Sussex
  • Me & My Motors are Truly 1 off's
    • Custom Mondeo TDCi Estate
« on: 29 July 2011, 16:09:11 »
I have got sitting in the car waiting to be fitted a full set of Xenon extra bright road legal bulbs, however I got the headlight cover off for the bulbs and managed to get the dipped beam bulb out however the main beam bulb and just cannot get it to budge out of the light! When I try to pull the bulb out the whole inside reflector part of the light tries to come with it.
Any suggestions please?
51M0N
  • Hull
Re: Can't Get My Headlight Bulbs Out!
« Reply #1 on: 29 July 2011, 16:10:59 »
pop the metal retaining clips out of the holders...
Should squeeze or pull out
« Last Edit: 29 July 2011, 16:11:18 by Simon131188 »
Stallion
  • Romford
    • 3.2 Irmscher Elite
« Reply #2 on: 29 July 2011, 16:27:13 »
should be push in, move to the left and it should pop off, also its good to keep a eye how the bulb sits and is positioned, when refitting!
« Reply #3 on: 29 July 2011, 17:09:37 »
well if the reflectors coming too....
youve broken the adjusters  :'(
see the how to guide for replacement (and parts for sale for replacements)
« Reply #4 on: 29 July 2011, 21:03:38 »
There isn't really room tbh.
It's debatable, but could either remove the headlights, or the battery and air box for access. If removing battery make sure you have any relevant radio codes first, and know that one touch windows and sun roof if present will need to be reset. Which is why I remove the head light instead.
 But you'll need a long 1/4 inch drive to acess the bottom bolt behind the lower head light trim which pushes out from behind. And tape the bolt on to the socket to re fit.
Depends which way you want to go, but in the interest of keeping the bulb clean and finger print free, I would choose one of the above options.
Hth.
tango
  • brum
« Reply #5 on: 29 July 2011, 21:05:20 »
i find it easier to pull the headlight out
makes it alot easier
especially if you got big hands
« Reply #6 on: 29 July 2011, 21:07:28 »
As Jimbob says. Adjusters are donald. Need replacing.
« Reply #7 on: 29 July 2011, 21:08:52 »
Hth.
I find it easier to push a lump of "Blu-Tac" into the socket :y
« Reply #8 on: 29 July 2011, 21:10:38 »
Mmm? :-? Maul about removing a headlamp to replace the bulb or just stick your hand in the back of the headlight & pull the bulb out?
I know which is easier. Main beam bulbs are just a push in fit - they're snug, but a push in fit.
« Reply #9 on: 29 July 2011, 21:34:30 »
Hth.
Oily sockets... Mmmm maybe. Blu tac is like copper slip though, IMO. Although you may have found the best use for it.  ;)
« Reply #10 on: 29 July 2011, 21:37:32 »
Hth.
Keep `em clean then ;D
« Reply #11 on: 29 July 2011, 21:48:34 »
Hth.
... :D and own an omega...?  ;D
