Author Topic: OOF'ers Views On ATF changes!  (Read 6122 times)
Stallion
  • Romford
    • 3.2 Irmscher Elite
« on: 21 December 2011, 07:48:20 »
3 Questions for those who have changed their gearbox oil..
1. just thinking what would OOF'ers views be on changing the ATF, is it more headache than it seems (DIY oil change)..
2. How did you guys know (any symptoms) that you needed to get the oil changed
3. What sort of mileage does Vx say to change it??
Thanx guys  ;) ;)
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: OOF'ers Views On ATF changes!
« Reply #1 on: 21 December 2011, 07:59:09 »
OOFers recomend a change every 60,000 miles.
I like red cars
Stallion
  • Romford
« Reply #2 on: 21 December 2011, 08:05:13 »
Im waay past that mileage  :( :(  so thats 1/3 reasons to do it.
« Reply #3 on: 21 December 2011, 08:24:44 »
Easy enough, but messy job.
remove both sumps,
clean / replace filter
clean mating faces, reassemble with new gaskets, or pref instant gasket
refill with new ATF
Shower, many, many times to get rid if the stuff.
about every 60000, but according to VX...sealed for life!
needs doing to improve smoothness of box really.
Stallion
  • Romford
« Reply #4 on: 21 December 2011, 08:30:12 »
Thanks Jimbob, now just need the courage to attempt it!  :-\
Stallion
  • Romford
« Reply #5 on: 21 December 2011, 08:31:18 »
Any idea how long it would take  ???
« Reply #6 on: 21 December 2011, 08:38:37 »
a good 1/2 day will be needed
Auto Addict
  • North Birmingham
    • Astra K Elite ST
« Reply #7 on: 21 December 2011, 09:00:12 »
remove both sumps,
refill with new ATF
Don't forget to get a new sump washer.
I like red cars
« Reply #8 on: 21 December 2011, 09:18:47 »
But if you find bits of plastic in the front sump....  .....double bugger!
Stallion
  • Romford
« Reply #9 on: 21 December 2011, 11:15:00 »
« Reply #10 on: 21 December 2011, 11:23:50 »
Thats the thrust washer, and a gearbox off job to replace.
« Reply #11 on: 21 December 2011, 11:39:51 »
Personally have never done this on a drive way, always sort a lift, either at a friendly auto specialist locally that I know, as it's got to be worth £60 labour for him to do it, or at a meet on here. Guffers cam belt meet was ESP handy with pits and lifts.
 Its very messy, and being able to stand straight under the car while working for such a length of time is a must for me.
Re symptoms, if your lucky, thumping while engaging gears is usually the first sign. If your unlucky, loss of drive, slipping, limp mode, and a fubar box.
Get the ATF changed.
Ps clean the filter, rather than renew.
« Reply #12 on: 21 December 2011, 11:48:42 »
Although, inviting debate on this, is it worth even cleaning the filter? ESP if no oddities are found.
It's not a fine mesh filter by any means. The magnet catches fine particles in the sump, so any large particles are for the filter to catch. Which can be removed or shaken out. And let's face it, if you've got large bits of debris you have a lot more to worry about than changing/cleaning the filter.
 Plus, given only a percentage of the ATF an be removed, a spanking clean filter seems a little pointless.
I suppose cleaning purely to check for debris is all that's needed.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #13 on: 21 December 2011, 11:54:50 »
Personally though Chris, if I was going to the trouble of dropping the sumps plus renewing the gearbox oil, I would put on a new filter.  :-*
« Reply #14 on: 21 December 2011, 13:53:03 »
I put a new filter on the first time round then cleaned the old one at my leisure, so it's ready for next time.
If it's done galactic miles on the current fluid I would have a new filter to hand in case the old one isn't fit to re-use. Besides, the chap who advertises in straight 6 news does filter plus gaskets for 30 quid IIRC.
