Author Topic: Central locking failure and key problems - MFL 2.5TD  (Read 1480 times)
Shackeng
  • Ramsbury
    • 3.2 Elite 2.0 TitX Mondeo
« on: 30 January 2012, 18:36:38 »
On my '99 MFL 2.5TD I suspect I have more than one problem.
1. Key 1 would not unlock car, and the red key indicator light stayed on. After some percussion adjustment the light went out and the key worked, however I swopped to using key 2 in case of further problems with this key. Can't see anything loose inside.
2. With Key 2, with a new battery, occasionally the central locking will not unlock, or at other times lock, not consistent. This one does not have a red light.
3. The driver's door solenoid has started to get 'lazy' or intermittent, even when the key(s) work(s) OK. I changed this about a year ago for one off here.
On another forum I read that the micro-switch in the solenoid is replaceable quite cheaply, has anyone done that on here?
I don't want to keep changing the solenoid, so may buy a new one if all else fails.
Does anyone know if Martin Imber is still doing keys? I see he was last on in November.
Shackeng
  • Ramsbury
Re: Central locking failure and key problems - MFL 2.5TD
« Reply #2 on: 30 January 2012, 19:39:36 »
Thanks muchly Kevin. Is Martin out of business do you know? :y
« Reply #3 on: 30 January 2012, 19:57:59 »
  ??? ??? ??? ;D :y
Sorry, don't know, I hadn't realised that he'd not been on the forum for so long.  :-\
Shackeng
  • Ramsbury
« Reply #4 on: 30 January 2012, 21:32:28 »
Sorry Andy, read the links and went into auto. :-[ :-[ :-[
jonny2112
  • Bangor NI
    • 2.6 Elite
« Reply #6 on: 30 January 2012, 22:31:40 »
Martin did my key at the end of November. Drop him a pm anyway, or contact via his website  :y
Shackeng
  • Ramsbury
« Reply #7 on: 31 January 2012, 20:09:15 »
Thanks for all that info. :y
Page created in 0.032 seconds with 16 queries.
