Pages: 1 2 3 [4] 5 6 7 8 9   Go Down
Author Topic: The Prize!  (Read 30371 times)
Webby the Bear
  • Northampton
    • 2000 (W Reg.) 2.5 V6 CD
Re: The Prize!
« Reply #45 on: 07 March 2012, 21:09:31 »
Evening chaps. Hope you're all well and all happy after the return of the stink pink  ;D
In preperation for my Cam Cover job at the weekend I have some Q's (sorry, I know I'm a pain.... but hey this is a car forum  ;D)
Ok, first things first...
Here is the wording from the guide on how to remove the inlet bridge:
Now de-pressurise the fuel system by removing the black plastic cap at the rear left of the injector rail, surrounding it in a dry rag and pressing the centre of the valve in.
Disconnect the air pipe from the fuel pressure regulator. Unplug the injector loom and remove the 6 securing bolts which hold the injector bridge assembly to the inlet.
Un-bolt the feed and return unions on the fuel rail(Caution some fuel will escape so surround it in a rag)
Remove the inlet bridge and injector assembly.
Ok, so I understand that to de-pressurise the fuel system I remove that valve cover (looks like the valve cap on the tyres) and presumably fuel will piss out and I should press down whatever lurks beneath that valve cover (sorry, never took it off).
Now the rest being 100% honest I don't know what/where these are:
Air pipe from the pressure regulator
Injector loom
6 securing bolts (can't nip out to check on the car as it's not here but not worried about these as I'm sure I'll be able to see them)
Feed and return unions (Are these the two that have the yellow fuel warning labels on?)
If anyone could advise or provide an idiots pic with arrows that would be sweeeet.
RIP Paul Lovejoy
Re: The Prize!
« Reply #46 on: 08 March 2012, 12:08:32 »
Valve is just like car. Not much will come out, so just a rag under it. More will come out when you undo fuel lines later.
The pipe is obvious - goes from ICV (non DBW) or Throttle body (DBW) to the fuel pressure reg.
Its all quite obvious when you get down there :y
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #47 on: 08 March 2012, 12:26:24 »
Thanks mate. May sound like I'm worrying but just really want reassurance that if I undo the wrong thing I won't A.) fry myself or B.) bake the car.  :y
RIP Paul Lovejoy
Re: The Prize!
« Reply #48 on: 08 March 2012, 12:36:23 »
Injector loom connector & the fuel feed/return unions shown here Steve
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #49 on: 08 March 2012, 12:42:24 »
legend, cheers roberto ;)
RIP Paul Lovejoy
Re: The Prize!
« Reply #50 on: 08 March 2012, 12:43:26 »
Glad to assist "Mr. Mechanic" :D
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #51 on: 08 March 2012, 12:50:20 »
 ;D ;D ;D That reminds me, I have my college interview on Thursday 29th March. Going to explain what limited knowledge i have and see where i'm best suited ;)
RIP Paul Lovejoy
Re: The Prize!
« Reply #52 on: 08 March 2012, 12:55:34 »
Behind the steering wheel :D :D ;D :y
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #53 on: 08 March 2012, 12:59:24 »
probably  ::) ;D ;D ;D
RIP Paul Lovejoy
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
Re: The Prize!
« Reply #54 on: 08 March 2012, 16:40:49 »
Hee hee! Good 'un Rob  ;D ;D ;D
bored bigyin54
  • south wales
    • black beast
Re: The Prize!
« Reply #55 on: 08 March 2012, 18:03:56 »
your not safe there steve ha ha
Webby the Bear
  • Northampton
Re: The Prize!
« Reply #56 on: 08 March 2012, 22:06:46 »
Agreed?................ :y :y :y :y Thanks Rob
RIP Paul Lovejoy
Re: The Prize!
« Reply #57 on: 09 March 2012, 08:52:13 »
Also , dont have a tab while you undo the fuel rail ...combustion is likely at a fast pace  ::) Health and safety an all  8)
Like the no nonsense diagram  ;D
Re: The Prize!
« Reply #58 on: 09 March 2012, 09:43:34 »
Spent a while working on someones car once with the fuel system in bits - he stood there and chain smoked next to it.. some people!
Incidentally, I didn't read (ahem) the bit about using the valve to release pressure when I did mine; so I just cracked the unions off with a towel under them. Nothing bad happened ;)
Re: The Prize!
« Reply #59 on: 09 March 2012, 22:16:10 »
The price of petrol now i'd be sucking the towel and spitting it back in the tank  :-X
Pages: 1 2 3 [4] 5 6 7 8 9   Go Up
