Author Topic: Electrical issues on Omega Elite  (Read 2454 times)
CMCE305
  • Manchester
    • Omega 2.6V6 Elite
« on: 27 December 2012, 09:41:07 »
I am hoping someone can help me with an issue on my Omega Elite which occured yesterday.  I hadnt driven it since Saturday and when I tried to go into it yesterday the dead lock on the drivers door didnt release with the central locking.  I used the key which unlocked it but when i started the car the Workshop light and the traction control light remained lit.  Also the lights on the selector for the gears where flashing and if i selected D the number 3 light was lit.  I switched of the car and turned it back on again and the problem went away. I drove about 15 miles on the motorway and stopped for about 1 hour and when i went to go back in again the same problem occured.  could someone help me as to what the problem could be?
Re: Electrical issues on Omega Elite
« Reply #1 on: 27 December 2012, 10:50:07 »
Driver's door lock is probably due to the locking motor. Have a read through these guides.  :y http://www.omegaowners.com/forum/index.php?topic=90504.0 http://www.omegaowners.com/forum/index.php?topic=90642.0
there's no 'workshop' light on your car, that's your Engine Management Light . 'Pedal Trick' will give you a code http://www.omegaowners.com/forum/index.php?topic=90594.0 but it could be your transmission selector if it's flashing your selector lights. http://www.omegaowners.com/forum/index.php?topic=90673.0
CMCE305
  • Manchester
    • Omega 2.6V6 Elite
« Reply #2 on: 27 December 2012, 11:20:36 »
Sorry to be so thick.  how do you do the Pedal trick.  i have found one which is press brake and accelarator pedal and turn ignition on to postion 2.  when I do this the EM Light flashes once then pauses then flashes 7 times then pauses, flash once and the 3 times.  how do you interpret this to the fault codes?
« Reply #3 on: 27 December 2012, 11:26:17 »
1713. Which doesn't sound right.
1700 is a TCM fault, which given the symptoms, is more valid. Clean the selector switch
« Reply #4 on: 27 December 2012, 11:26:44 »
That's the pedal trick you've found ...... not sure how that equates to a code though (assuming you've counted the flashes correctly  ;) )
CMCE305
  • Manchester
    • Omega 2.6V6 Elite
« Reply #5 on: 27 December 2012, 11:39:26 »
i have done this again and got codes 1613, 1612 and 1700.  looks like i have to do the TCM.  is this an easy job or should i get someone to do it for me?  if so is there any members in Manchester area that can do this?
« Reply #6 on: 27 December 2012, 11:46:32 »
ignore the 2 immobiliser ones for now. 1700, as expected, given symptoms, so clean the selector switch (under car, passenger side of box)
« Reply #7 on: 27 December 2012, 11:47:36 »
Or PM Elite Pete (think he's Chester), and buy a known good one from him (and fit, if you're not confident)
CMCE305
  • Manchester
    • Omega 2.6V6 Elite
« Reply #8 on: 27 December 2012, 11:52:50 »
Thanks i will have a look at it first and then decide what to do  :y
« Reply #9 on: 27 December 2012, 11:53:54 »
Its not a bad job, though the precat is a bit in the way
CMCE305
  • Manchester
    • Omega 2.6V6 Elite
« Reply #10 on: 08 January 2013, 22:37:49 »
Many thanks to all responded.  didnt have time to work on it so sent it to a automatic gearbox garage and £60.00 later it is back working correctly again.  was exactly as diagnosed.  I just have to change the door lock solenoid now which i got from Omegaspares.com and should all be happy again ;D :D :y :y
Page created in 0.021 seconds with 16 queries.
