Pages: 1 ... 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18   Go Down
Author Topic: TB's Garage thread  (Read 56252 times)
Re: TB's Garage thread
« Reply #150 on: 11 June 2014, 14:05:43 »
TB
For us newbies what actually happened to your garage?
Just think BANG    ::)
Only bigger and more shouty :y
« Reply #151 on: 11 June 2014, 14:07:40 »
Same as Jamie then ..........  ::)  ::)  ;)
« Reply #152 on: 11 June 2014, 14:08:22 »
Like this...
BANG
« Reply #153 on: 11 June 2014, 14:09:12 »
Block and beam floor in a garage?
Yup.  I always wondered why both the garage and house were on a suspended floor, and its only when going through planning for the garage rebuild that its due to "shrinking clay", whatever the hell that is. Google turns up a load of conflicting info as to what it is.
Whatever, planning would not allow a solid floor for the garage.
« Reply #154 on: 11 June 2014, 14:10:07 »
Blocks just arrived, just as I saw the builders drive the other way ;D
« Reply #155 on: 11 June 2014, 14:10:55 »
It's clay. That shrinks. Duh  :P
Probably in the cold.. I think we can all relate.
« Reply #156 on: 11 June 2014, 14:10:55 »
Thec prospect of unloading them does that to people ;D
« Reply #157 on: 11 June 2014, 14:28:14 »
TB
One morning last summer, it instantaneously went from:
to:
Made a mess of the car as well :(
« Reply #158 on: 11 June 2014, 14:31:08 »
That second photo is ripe for some captions, from two firemen  ;D
« Reply #159 on: 11 June 2014, 14:33:34 »
Very odd, for a few reasons.
1) Planning dont have a clue about anything structural, that is a building control job (guessing a full plans submission so its pre-approved and the builder can ignore it as they tend to  ;D ;D).
2) A properly constructed concrete floor bears on both the ground underneath and the foundations.
It quite usual to have a house with BnB build but a garage has much greater point loads, hence my surprise (
 checking the suppliers sites it seems to be possible although its recommended to use a stronger beam at circa 170mm wide and it must have a steel reinforced screed on top......so get your tape measure out!)
chrisgixer
« Reply #160 on: 11 June 2014, 14:37:18 »
I presume there's a risk the clay underneath can dry out, and hence retract. There by leaving a normal concrete floor un supported and at risk from cracking...?
« Reply #161 on: 11 June 2014, 14:51:36 »
If the floor was reliant on the clay for support........as said, a reinforced slab which extends to the poured foundations would not be reliant on the clay underneath.....
« Reply #162 on: 11 June 2014, 14:53:26 »
I know planning made some insistence on it, possibly because the architect said it needed it. The builders have had the building inspectors out to check if its necessary, and apparently it is.
« Reply #163 on: 11 June 2014, 15:05:45 »
Guess where I kept them all...
« Reply #164 on: 11 June 2014, 15:07:45 »
As said, planning are not able to enforce such matters (they may, and its a very long shot, offer a condition or advisory but its VERY rare) and wont even review such detail as the document submission requirement for planning wont have this level of detail on it :y
For them its all appearance, sustainability, impact,  yada yada yada
Building control however can insist on it (even if its not best solution) and they will review the approve the strutural build etc in line with the building regs.  :y
Pages: 1 ... 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18   Go Up
