Author Topic: Electric Oven Probs...  (Read 2228 times)
« on: 18 November 2008, 18:59:57 »
An oven that used to take 20 mins to heat up, now takes 30-40 minutes.
What do you think is wrong?
I'm thinking replace the element, only £20.
Re: Electric Oven Probs...
« Reply #1 on: 18 November 2008, 19:02:35 »
if fan assisted, could be fan as well.
« Reply #2 on: 18 November 2008, 19:05:05 »
It is fan assisted, fan is certainly working....
« Reply #3 on: 18 November 2008, 19:13:31 »
I think there is a thermostat somewhere, but sounds more likely element, esp if light goes out at right temp.
dieseldean
  • chesterfield
« Reply #4 on: 18 November 2008, 19:22:45 »
if my oven packs up then i'll just wrap food in tin foil and place on tractors exhaust manifold ;D ;D ;D
« Reply #5 on: 18 November 2008, 19:22:53 »
According to the light, it does maintain its temp,
Maybe I should do some thermometer checks as well.
Debs.
« Reply #6 on: 18 November 2008, 19:24:40 »
 ::) I expect `my ideas of what might be wrong would be considered to be half-baked! ;D
« Reply #7 on: 18 November 2008, 19:26:03 »
It Starts!
Cheers Debs  ;D
STMO123
« Reply #8 on: 18 November 2008, 19:35:22 »
What? An oven should take, like, 2-3 minutes to get to working temp. Mine does.
michael.d.s.
  • glasgow
« Reply #9 on: 18 November 2008, 19:42:11 »
2-3 minutes  :-? do you have a nuclear reactor inside . it takes 4 minutes for a standard electric element to achieve core temperature , a further 6 minutes for the air inside to reach the same temp and a further 6-8 minutes for the walls to reach the same temp depending on insulation , what you are aiming for is thermal equilibrium , which means that the convection current temperature within the oven cavity is the same at the top as it is at the bottom then click goes the thermostat which is usually a bi-metalic pressure switch .
STMO123
« Reply #10 on: 18 November 2008, 19:43:40 »
Wow!  Well I've just tried it (I'm anal like that) and the light goes out after 6 mins.
« Reply #11 on: 18 November 2008, 19:45:22 »
Mine takes about 5-6 mins to heat up.....
These elements are sometimes a dual winding......what is the make and model?
« Reply #12 on: 18 November 2008, 20:04:47 »
We've notice our top oven is taking ages to heat up lately.  I guess I should look at it, but its easier to preheat on grill, then flick oven on ::)
Taxi_Driver
« Reply #13 on: 18 November 2008, 20:42:58 »
Mine takes ages to heat up too.....and its a fan oven.....so do what i do.....turn oven on and take Holly for a walk.....when u get back oven is upto temp  ;D ;D ::)
Might be a bit of distance tho to come and walk Holly  ;D ::)
« Reply #14 on: 18 November 2008, 20:48:55 »
Its quicker to go for a takeout ;)
