Pages: 1 [2] 3 4 5 6 7 8 9 ... 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31363 times)
HerefordElite
  • Hereford
  • Welcome to the Shire
Re: Off with its head (s)!!!
« Reply #15 on: 05 March 2009, 21:25:36 »
what have you removed from behind heads / top of gearbox it looks bare?
only coolant and breather pipes.  remember no dis on 2.6
ah that's what's missing ;)
« Reply #16 on: 05 March 2009, 21:25:59 »
Real stupid question here but does the block sit level in the car? I only ask because I notice there is coolant at the back of the reservoir area where the oil cooler sits but not uniformly across the whole of it?
Or has all the kit you have removed from the engine lessened the weight of the front of the car?
Its lowered the weight quite a bit!
So the suspension is sitting a bit higher and teh drive slopes away from the house  as well
« Last Edit: 05 March 2009, 21:26:17 by Mark »
« Reply #17 on: 05 March 2009, 21:27:26 »
Wouldn't be a DIS in that shot anyway, its attacehd to the head!
Good point, well presented  :-[
The engine bay will get a bit of spit and polish whilst its stripped down to!
That I don't doubt ;)
Matchless
  • Nottingham
    • A white van
« Reply #18 on: 05 March 2009, 21:28:57 »
Have you got a new crank seal yet?
« Reply #19 on: 06 March 2009, 00:04:51 »
Here's one for you: What path does coolant flow take around these engines? Can't quite get my head around it from those photos.
I can see that the flow from the transfer pipe goes into the rear of the oil cooler area, and down into the water jacket around the bores, by the look of it. Presumably it finds its' way to the water pump, and into the thermostat area but how are the heads cooled? Surely all the head cooling water doesn't flow up from the water jackets and through the coolant bridge and heater circuit, does it? Or is that a separate channel feeding the front of the head from the water pump?
« Reply #20 on: 06 March 2009, 02:48:26 »
had presumed, in through the top of the stat chamber(seperate to cooler chamber) out through the hole under stat, down to the water pump which pushes it round the jacket and up into the oil cooler chamber, then out the back of the block???
« Reply #21 on: 06 March 2009, 08:08:55 »
I will see if I can draw a diagram up
markey mark
  • SLady bitshorpe north lincs
« Reply #22 on: 06 March 2009, 13:38:05 »
i have just rebuilt mine mark with facelift manifolds ported the heads on exhaust side put 4 g cams in junked the egr and sec air inj system heads were refurbed skimmed all new inlet valves new valve seals all valves re lapped runs sweet and does have a lot more go in it !  :y
« Reply #23 on: 06 March 2009, 13:42:08 »
Yup, the 4G cams on the exhaust wont deliver anything sadly as they offer only improved duration and that does not aid the exhaust side of things (its pumped and the gases exit quickly due to the valve actualy opening towards the bottom of the firing stroke)
The ports on the later manifolds are much bigger and if you junk the air injection you can really open the head out.....the manifolds are SO much better to!
The more I look at the later setup the more it would appear that the emission changes were lowering the output power so they HAD to work on the ancillaries to get the output back up in order to be a viable replacement for the 2.5 and 3.0
markey mark
« Reply #24 on: 06 March 2009, 13:44:32 »
surely if the valves are open longer the scavenging effect will be higher on the exhaust side ?? the facelift manifolds are way bigger must have took 2/3mm of the ports and flattened the ridge in middle  :y
Martin_1962
« Reply #25 on: 06 March 2009, 14:00:47 »
Could do with a list of where to grind as I might port mine while they are off
markey mark
« Reply #26 on: 06 March 2009, 14:20:47 »
just open them out to the gaskets martin  :y
  • Online Online
« Reply #27 on: 06 March 2009, 14:42:17 »
So we all need a DBW inlet manifold to butcher modify with a Dremel/die grinder to get a few more horses out of our earlier cars!  :y
« Last Edit: 06 March 2009, 14:42:28 by Andy_B »
markey mark
« Reply #28 on: 06 March 2009, 15:06:36 »
no andy dbw exh manifolds  :y
« Reply #29 on: 06 March 2009, 15:11:50 »
Should have worded it better, the cams open and close the valve at the same points but, the period spent at the higher lift valve is longer on a G cam.
Scavenging is more related to the point of opening than the lift.
Hence buggering with the cam timing can yield some gains (vernier cam sprockets needed to do this as you need to adjust exhaust cam with respect to inlet).
Pages: 1 [2] 3 4 5 6 7 8 9 ... 17   Go Up
