Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 ... 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31389 times)
Martin_1962
Re: Off with its head (s)!!!
« Reply #75 on: 08 March 2009, 21:18:11 »
Will .8 compression really make that much difference??
Yes - Look at this thread earlier - they tuned the DBW engines to make up for power loss.
I reckon 2 or 3 bhp minimum would be found but also better mpg
Is it worth it, for a barge?
Given the additional cost is small and only involves time (your won)......then why wouldn't it be  :y
I am buying a spare pair of heads to refurb so will be investigating skimming very seriously.
Will be porting too. Years since I've ported.
Done a 33% improvement on a 100cc bike and 66% improvement on a Hillman design push rod lump
« Reply #76 on: 08 March 2009, 22:06:05 »
Ok, stripped a head down today.
Here is a pic of the trouble stem seals.
The green one is the standard Vx stem seal as used throughout the 2.5 and 3.0 production run plus most of the other big block 4 pots to!
The red one is the issue, it is vey hard and I could simply pull it off the guide with my fingers (compared to the ones on TB's old heads which required special pliers and brute force to shift even at 10 years old and 100K+ miles).
Now these came into existance because some low life, sorry purchasing person, decided to try to save a penny a seal by using an alternative which had not been proven!. I trust they were sacked, fired and buried for that one!
Here are all the removed items, these will be soaked in caustic soda for 24 hours before having a good hot rinse and final clean in an ultrasonic bath.
And the head, this will gently 'bleed' old oil until I get a chance to pressure wash it down ready for a bit of 'touching in'
« Last Edit: 08 March 2009, 22:07:31 by Mark »
Martin_1962
« Reply #77 on: 08 March 2009, 22:10:28 »
Valve seals - I need 24 of them - same reasons
Might call Trachii and ask them what colour theirs are
« Reply #78 on: 08 March 2009, 22:11:44 »
There green
I got 16 very cheap on ebay (genuine) and then bought 8 more from the dealer at just over a quid each
« Reply #79 on: 08 March 2009, 22:17:34 »
There green
 :o
dont ask how much are they here :(
« Reply #80 on: 08 March 2009, 22:21:15 »
There green
 :o
How much Cem? ;)  ;) 2 000 000 Turkish Lira?
(I think you've lost a few zeros since I last went to Turkey though  :y  :y)
« Reply #81 on: 08 March 2009, 22:24:39 »
There green
 :o
2 years ago when foreign currency rates were low they were 350 quid nearly 750 tl for a 24 set .. I'm afraid to ask now :(
« Reply #82 on: 08 March 2009, 22:33:49 »
You mean 750 MILLION TL?  :o  :o  :o  :o
Postage from UK to Ankara can't be that much!  :y  :y  :y
« Reply #83 on: 08 March 2009, 22:37:22 »
yep..I'll definitely want help when I decide to change them.. VX/Opel here sometimes make legal robberies.. >:(
Thanks  :y
« Last Edit: 08 March 2009, 22:44:04 by cem_devecioglu »
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #84 on: 08 March 2009, 22:47:23 »
[/quote]
2 years ago when foreign currency rates were low they were 350 quid nearly 750 tl for a 24 set .. I'm afraid to ask now :([/quote]
£14.50 for a stem seal :o :o :o :o :o
« Last Edit: 08 March 2009, 22:51:48 by herefordelite »
« Reply #85 on: 08 March 2009, 22:49:32 »
There green
 :o
estimate , how  much I pay for all those list I've changed :'( :'(
shocks 300 £
cambelt 180 £
wishbones 350-370 £
and many sensors etc etc list goes on :'(
« Last Edit: 08 March 2009, 22:51:18 by cem_devecioglu »
« Reply #86 on: 08 March 2009, 22:52:32 »
so I deserve to be the most stupid member medal ;D :y
HerefordElite
  • Hereford
« Reply #87 on: 08 March 2009, 22:55:10 »
good news Mehmet exchange rate is better at moment 750TRY = only 296GBP  :D
Sure anyone on here would sort parts and postage for you if you need bits :y
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
« Reply #88 on: 08 March 2009, 22:56:05 »
Surely you could get parts sent from the UK much cheaper than that.
TuBy's new whipping boy.
« Reply #89 on: 08 March 2009, 22:57:04 »
problem is the GBP part is fix TRY part changes so they profit more :-[
« Last Edit: 08 March 2009, 22:57:23 by cem_devecioglu »
Pages: 1 2 3 4 5 [6] 7 8 9 10 11 12 13 ... 17   Go Up
