Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31360 times)
PaulW
  • Somewhere near Manchester
  • Come on you fiend!
    • Some crappy Insignia
Re: Off with its head (s)!!!
« Reply #45 on: 06 March 2009, 22:32:03 »
bloody hell thats a bad one!!!
Humbugs...
« Reply #46 on: 06 March 2009, 22:33:41 »
Yep, you have to wonder if this is part of the cause of cat in-efficiency issues!
« Reply #47 on: 06 March 2009, 22:35:19 »
Manifolds really differ.. and will change the power curve also..
« Reply #48 on: 06 March 2009, 22:37:15 »
Should increase the top end, not much lower down as there still not perfect.
But, with the better inlet setup and 3.0 cams plus good stem seals it should run nicely!
« Reply #49 on: 06 March 2009, 22:43:54 »
how many extra ponnies  :)
« Reply #50 on: 06 March 2009, 22:44:56 »
20+ I would say.....should be close on 200bhp when I have finished fettling it (its a 2.6)
« Reply #51 on: 06 March 2009, 22:48:31 »
any plan for visiting south countries like Turkey ;D :y
Omega man 2
« Reply #52 on: 06 March 2009, 23:02:19 »
Been watching this thread with interest ::). After seeing what a rebuild does to a 4 pot without any mods.
Planning on rebuilding a v6 when I get hold of one.
But with lower compression on the 2.6/3.2 and changing the ancilleries to make up for this. Does that mean a 2.5/3.0 could potentialy have more power if the best bits from both engines were fitted?
HerefordElite
  • Hereford
  • Welcome to the Shire
« Reply #53 on: 06 March 2009, 23:04:11 »
But with lower compression on the 2.6/3.2 and changing the ancilleries to make up for this. Does that mean a 2.5/3.0 could potentialy have more power if the best bits from both engines were fitted?[/quote]
hope so, i'm already watching some 3.2ex manifolds on egay ;)
« Last Edit: 06 March 2009, 23:04:32 by herefordelite »
PaulW
« Reply #54 on: 06 March 2009, 23:15:47 »
I'm confused...
Facelift has different nuts for holding the manifold in place, yet same studs???
Part numbers differ on the nuts...
Humbugs...
HerefordElite
  • Hereford
« Reply #55 on: 06 March 2009, 23:23:36 »
I should add, those heads are gonna take some cleaning!
Better get Mrs DTM a new dishwasher on order now :D
markey mark
  • SLady bitshorpe north lincs
« Reply #56 on: 06 March 2009, 23:47:52 »
I'm confused...
yep 13mm om early ones 10mm on later ! also to those thinking of fitting 2.6/3.2 manifolds on 3.0 cars the lip on the top of the front pipes needs choping down to 4mm from 10mm  :y
PaulW
« Reply #57 on: 06 March 2009, 23:52:27 »
I'm confused...
So its just purely the bolt depth/height which differs then?? As the thread is the same...
Humbugs...
MikeDundee
  • Costa Del Peckham
« Reply #58 on: 07 March 2009, 02:18:24 »
Kepp up the good work Mark :y.....just one query though, thought you were just gonna keep an eye on the tyre pressures :-X.....why's the engine in bits :-X ;D
Martin_1962
« Reply #59 on: 07 March 2009, 08:59:54 »
I am planning on doing the same in May on a few days off - is it possible to do in two days from switch off to running again?
Pages: 1 2 3 [4] 5 6 7 8 9 10 11 ... 17   Go Up
