Pages: [1] 2 3  All   Go Down
Author Topic: Here we go again!!!!!!!!  (Read 2588 times)
LJay
  • North Wales
  • The Acrobatics Queen!
    • 3.2 - MV6 Big Blue!
« on: 31 August 2009, 17:39:12 »
It's bank holiday and our electricity supply is down to 190 volts!!! >:(
This happened last bank holiday and resulted in the electricity company coming out and digging up the road, changing our supply on to a new spur, filling the hole and going again!
Problem solved!     ........or so we thought! >:( >:(
Watch this space!!!!!!
Been there, fallen over it!
Re: Here we go again!!!!!!!!
« Reply #1 on: 31 August 2009, 17:43:43 »
the old saga....
http://www.omegaowners.com/forum/YaBB.pl?num=1241455595/all
lets see if the service is as good this time  :y
Taxi_Driver
« Reply #2 on: 31 August 2009, 18:10:06 »
Sounds like the 'old spur' was  getting overloaded.....so by switching you to another one....sorted it.....trouble is they probably swapped everyone else with a problem to that spur as well....now that one is getting overloaded too....bet they swap you back again  ::) ;D
LJay
  • North Wales
« Reply #3 on: 31 August 2009, 18:22:35 »
166 volts and getting dimmer!!! >:(
Engineer due within 3 hours!
KillerWatt
« Reply #4 on: 31 August 2009, 18:24:39 »
You are aware that you can sue your supplier for failing to maintain a constant (within 10%) voltage supply & frequency?
PS
Your fixed figure for working out the 10% variable is 230 volts in the UK (that means 23 volts either way from the 230V).
« Last Edit: 31 August 2009, 18:26:00 by KillerWatt »
STMO999
« Reply #5 on: 31 August 2009, 18:28:09 »
Mains supply or Jimbob?
LJay
  • North Wales
« Reply #6 on: 31 August 2009, 18:29:19 »
Phone call from help desk, we are 1 of 196 with the same problem! Engineers are working on it and we should have power back by 9 pm!
158 volts!
LJay
  • North Wales
« Reply #7 on: 31 August 2009, 18:30:16 »
Currently both!!!! ;D ;D ;D
KillerWatt
« Reply #8 on: 31 August 2009, 18:32:28 »
158 volts!
Count yourself lucky your PC uses a switched mode PSU then, otherwise you wouldn't be online at all to complain about it  ;D
LJay
  • North Wales
« Reply #9 on: 31 August 2009, 18:35:27 »
158 volts!
Theres always the laptop battery and someone elses unsecured broadband! :P :P
KillerWatt
« Reply #10 on: 31 August 2009, 18:37:55 »
158 volts!
All well & good until you realise the unsecured broadband is fed from the same phase as you  ;)
LJay
  • North Wales
« Reply #11 on: 31 August 2009, 18:40:00 »
158 volts!
No one else is reporting problems, its linked to the phase we were changed on to in may! ;)
KillerWatt
« Reply #12 on: 31 August 2009, 18:52:42 »
Come again?
« Last Edit: 31 August 2009, 18:56:04 by KillerWatt »
nick v6
  • walsall / west midlands
« Reply #13 on: 31 August 2009, 18:52:54 »
158 volts!
better feed the hamsters :y
« Reply #14 on: 31 August 2009, 18:54:20 »
158 volts!
 :o :o
even here I havent seen below 195 :-?
Pages: [1] 2 3  All   Go Up
