biggriffin
New disc's pagdids,new pads GM. Bleed system. Job jobbed. 8)
Hoof'land storeman.
Quote from: biggriffin on 25 July 2015, 16:07:16
Quote from: tunnie on 25 July 2015, 15:47:15
Hole in the condenser, local garage want £250+vat to supply, fit and regas  :(
£110 for condenser and £40 ish for recharge.
£120 labour isn't too bad if you can't diy :-\
Changed the PCV valves and did a little under bonnet detailing on the 645 (no Cif though so I had to use carb cleaner..)
steve6367
steve6367
Last 2 are at Lee on Solent currently - future is uncertain though
Delroy47
Bliss  :)  installed my sub and amp into the Elite with help of bruv, now I can pump me reggae chunes  :y
Quote from: Delroy47 on 26 July 2015, 08:26:47
I wondered why my head was throbbing today, I'd initially thought it was the beer yesterday
BazaJT
Fitted new plugs and leads car now running sweet as.Just got to wait now for next thing to go wrong[and it will]
In the brief moments I managed to get electric, I charged up the compressor, so I could pump up the tyres.
Quote from: Harris K Telemacher on 25 July 2015, 21:06:58
It's reasonable. If I factor in fuel and beer tokens for a fatty admin, not vastly cheaper. That said, 3.2 is well over due a belt change. So a visit to fatty is in order anyway :)
GastronomicKleptomaniac
Three evenings work on MrsGK's Golf cabby - timing belt, water pump, radiator, service... Would have had it done quicker if Jürgen and Helmut hadn't decided to fit a different tensioner to the Cabriolet engines, as to any other Mk3 engined 2.0.
Huge thanks to The Jason at AGP, as ever, cracking service, and what a gent. :y
EMD
Started the 2.5 after a month , sounds smoother than the fast black one  ::)
Tyre on the front is making a hissing noise  :(
Omegatitis
Washer fluid warning on mid, then check oil too. Which did go out after less than 60 seconds  :-\
Checked after cooled for 30 mins or so, still 70% of way up the dip stick. Topped up oil and screen wash.
Reminded again that I really must get the 2.2's arse in the air, to check the knocking from the back  ;D
Fitted some proper metal coolant outlet elbows to the LPG vapouriser to replace the plastic rubbish. I defy it to leak any more. >:(
