Hmm. No obvious smell of coolant, although I keep convincing myself I can smell a whiff every now and then. Loses a pint of coolant every day or two, and I can't see an obvious leak. I need to find some time to take the plenum off and have a good look with some pressure on the system. Could be leaking into the valley and evaporating, I suppose. Could even be the HBV but I'd have thought that would be obvious given the rate of leakage.
No sign of any leakage around the transmission tunnel or the end of the heater matrix that I can see...
If you have mats, then it might not be obvious on top... Also don't rule out the main radiator... :-\
Quote from: Harris K Telemacher on 13 July 2015, 22:44:33
Got a dead osr inner brake pad from the noises it's making when the pedal is pressed...
Bloody Tc has been working too hard ::) :-X
Job for tomorrow...
As suspected ::) 10 minutes and ten quid later, all is well in the world :)
Also had Autowrongglass turn up with a standard green top windscreen. Chap was really impressed... Having driven all the way from Eastbourne with it ;D
Only eight weeks since originally ordering it >:(
Put those pads back in until you've had your money's worth! I can still see a little friction material on them! ::)
chrisgixer
Quote from: Kevin Wood on 14 July 2015, 10:59:22
Might be worth getting a hand under the hbv with ac on and off, before removing plenum....?
Mine was loosing coolant down to a certain level over a week. Then the level would stay at that point for months. Then the hbv failed dramatically. Changed it, and the level now stays correct. So presume the hbv was leaking slightly for some time before it failed properly. Often got a waft of coolant but from outside when engine hot.
New wishbones seem to have lost their front bushes  ::) ;D
Many thanks to the garage I use  :y Always handy having a 50T press!!!
Friendly Aircon place I use have changed the pressure sensor and re-gassed the Alhambra thus morning. Nice and cool in the old bus now.  :y
Just spent the rest of the day cleaning the thing!
BazaJT
After last Sundays farce of yet another breakdown,I've replaced the hbv.What a lovely job that is but I'm fairly confident that if I live long enough the scars will heal :D
EMD
Quote from: Kevin Wood on 14 July 2015, 12:59:52
;D ;D ;D
Omegatitis
chrisgixer
Put a hole in the side of the petrol mower housing. Does that count?
Mr.OmegaMan
Picked up this evil little b*****d the other day >:(
Just my luck its not repairable according to 3 garages.
chrisgixer
mka306
Even though that tyre would fail an mot you can get tyres repair kits that would save that tyre at least until your next mot.p
Quote from: mka306 on 19 July 2015, 10:16:38
You might find a tame tyre place to repair it (I know I could ;)) but would you trust it? I wouldn't...
