Genuine last longer and aren't significantly more expensive :y
Quote from: EMD on 12 July 2015, 17:00:53
Time to pull the fuse on the sunroof , click click click click open shut open shut all the way to Billing and back with the a/c escaping the hatch  ::) Now to find which fuse to pull without Please read the manual  ::)
Give the black disc a clean  :y
chrisgixer
Quote from: BazaJT on 12 July 2015, 19:28:22
Drove it about 5miles and broke down.HBV let go big style for some reason.No little leak or any other indication it was about to do so.I take it these are GM only-just about everything else on these seems to be!
As with most pattern shite, If you want it to last more than 5 minutes, get a GM one. ETS exhausts and or supplier stuff aside of course.
chrisgixer
No, read the guide. Why do we bother with a guide section? ;D RTFG! ;D
EMD
Quote from: chrisgixer on 12 July 2015, 21:03:37
Deaded sunroof again  :) I read tfm  :D
Omegatitis
Quote from: Andy H on 11 July 2015, 20:43:42
Spent the afternoon stripping the Galaxy to get the turbo out.
Haynes tells us to balance the engine on a piece of wood and a trolley jack then pull the engine forward to access the turbo - er, no thanks  ::)
Got the inlet manifold, EGR and EGR heat exchanger out without snapping any seized studs :) Tomorrows task is to get the exhaust manifold and turbo out, split it so I can free up the vanes then put it all back together - simples (I hope) ::)
Another 7 hours in the rain and I finally got the turbo on the bench :y
What is the definition of a bastard bolt? If it is one that you cannot see and can only touch with one finger while your wrist is raked by hose clips then there must be about 20 I had to undo  >:(
chrisgixer
Quote from: EMD on 12 July 2015, 21:21:49
manual tells you how to use it. Not how to fix it. RtfGuide. ;D
Steve B
Quote from: chrisgixer on 12 July 2015, 22:02:47
Oh you can be such a Bitch  ;D
BazaJT
Not really over fussed how long a pattern HBV would last as once it's on and sorted car only has to get about 4mls. to the car selling centre/auction place here in town and then hopefully I'll be rid of it.On a pence per mile basis it is from memory the most expensive car I've had,even the XJ comes in considerably cheaper!!
Got a dead osr inner brake pad from the noises it's making when the pedal is pressed...
Bloody Tc has been working too hard ::) :-X
Job for tomorrow...
Had a quick check to see where my coolant is going to. Hmm. Anyone know where it ends up if the heater matrix fails? ::)
chrisgixer
O-oh. Into the footwell usually, can you smell it in the car?
Quote from: Kevin Wood on 13 July 2015, 23:11:43
If it fails spectacularly enough, doesn't it spray your feet? :-X ::)
Soaks into the soundproofing and rots that long before the carpets get wet...
