Quote from: tunnie on 20 July 2015, 19:02:40
Quote from: chrisgixer on 20 July 2015, 18:51:24
Quote from: tunnie on 20 July 2015, 18:47:46
Poxy aircon bust already. Only lasted a month  :'(
Need to inspect, thoughts? Compressor seals, condenser leak?  :-\
Needs identifying where the leak is. Could be anywhere. Uv glasses and a lamp required if it had die in it.
But condenser is favourite culprit usually. Car cooling link on here somewhere if so. (Link in parts iirc)
Yeah got their details. It's not sounding right either, almost metalic whistling sound from centre vents. Which can be made to sound normal, putting to lo and back again. Climate reset still the same
So inspected it, not got the right tools but can't see anything clear like a big leak. Bottom of the condenser is intact, nothing falling down. Around the compressor looks ok, road but nothing green.
Some dye around HP valve, but could be from when they put it in.
EMD
Quote from: pauls on 20 July 2015, 18:39:32
Took it upto serek to get pre-cat sensors moved. Allso had alook at my backbox to find its knackered >:(
The advantage of a lift is you get to see whats really knackered  :( Hope you got it fixed  :y
Omegatitis
chrisgixer
Where the pipes meet the box sort of area?
If so mine went the same. Bought a new standard box and had that welded (braised actually) onto the back of the Irmscher one. Good as new really.
So all is not lost. :)
pauls
Quote from: chrisgixer on 20 July 2015, 19:58:04
No mate he cut it open and the left hand baffle has rotted away and left a big hole in the baffle.
chrisgixer
Quote from: pauls on 20 July 2015, 20:06:30
Re build able?
pauls
chrisgixer
Quote from: pauls on 20 July 2015, 20:15:29
Not on my budget  :'(
Bah. Well they sound better with an empty box. ;)
henryd
Quote from: tunnie on 20 July 2015, 19:28:19
Could be that valve is faulty,plenty here have had them leak in the past
other rides
chrisgixer
My condenser was leaking at a pin hole half way up. No way to see it without the right gear. Tbh
If it lasted a month, the leak is very tiny. Hence dye is your friend.  Did they put dye in (if not, they are retards)?  Given you won't have a UV light, led torches at night in the dark are reasonably effective
BazaJT
Picked up a set of double silicone plug leads-oops,sorry they're called ignition leads now aren't they?-and a set of spark plugs,now just need the time/weather to be right to fit them.
biggriffin
Quote from: TheBoy on 21 July 2015, 18:22:43
Most daleks now days use a fluorescent green dye,which is visible by eye, its in the refrigerant.
Check pipes near battery, usual place is bottom of condenser were you cant see it, if you have ramp access, brilliant, otherwise get it up as high as you can and look really close, undertray off to.
Hoof'land storeman.
flyer 0712
actually got around to finish off wiring in the after market reversing sensors. :y
Lagondanet
Thinking about it, more like two weeks it lasted. Yes dye in, it's going back later this week to be checked.
Quote from: henryd on 21 July 2015, 09:13:49
I changed the HP one (one near air intake) - once re gassed it lasted quite well. Maybe 3 or 4 months. This time just weeks :(
