biggriffin
Quote from: tunnie on 20 July 2015, 19:28:19
Quote from: tunnie on 20 July 2015, 19:02:40
Quote from: chrisgixer on 20 July 2015, 18:51:24
Quote from: tunnie on 20 July 2015, 18:47:46
Poxy aircon bust already. Only lasted a month  :'(
Need to inspect, thoughts? Compressor seals, condenser leak?  :-\
Needs identifying where the leak is. Could be anywhere. Uv glasses and a lamp required if it had die in it.
But condenser is favourite culprit usually. Car cooling link on here somewhere if so. (Link in parts iirc)
Yeah got their details. It's not sounding right either, almost metalic whistling sound from centre vents. Which can be made to sound normal, putting to lo and back again. Climate reset still the same
So inspected it, not got the right tools but can't see anything clear like a big leak. Bottom of the condenser is intact, nothing falling down. Around the compressor looks ok, road but nothing green.
Some dye around HP valve, but could be from when they put it in.
New LP valve aswell, after its been gassed, remove dust caps and put some soapy water on them, also spray condenser with soapy water. Looking for bubbles.
Hoof'land storeman.
Quote from: biggriffin on 21 July 2015, 21:20:52
I was advised NOT to use soapy water on the valves as it a) leaves a residue that can contaminate the system b) can cause rust (?) or other problems with the schrader valve. c) if just gassed then the soapy water can react with the refridgerant to exagerate a) & b).
The advice I was given was to pour a small amount of PAG fluid into the valve and to then watch for any bubbles rising through the PAG fluid.
I know nowt about air con systems .. this is just the advice given by the mobile fitter who came and sorted mine out. He even left me a small jar of PAG fluid in case I needed to check the valves at any time in the future.
I know nothing .......
chrisgixer
Quote from: Entwood on 21 July 2015, 21:41:43
Similar story with LPG leaks. Soapy water works, but causes corrosion.
Trouble is the leak spray that is supposed to replace soapy water doesn't really work in showing the bubbles. ;D
Anyway. Any oil based fluid would show the bubbles but not cause corrosion. 3 in 1 oil perhaps.
biggriffin
Last condenser I changed was 12years old, been coated in road salt,rain, car wash, and other road type detritus, its alloy, the pipes are alloy, I don't think a little squirt of a soapy solution is going to corroded it or dissolve it within minutes.
Hoof'land storeman.
Quote from: biggriffin on 22 July 2015, 08:50:05
Totally agree .. I was referring to the VALVES not the condenser or other external bits ....  :y :y
Just as pointer, the soap wont contaminate the refrigerant and cant, its at atmospheric pressure and the system at many PSI (many hundred in the case of HP side). It might as a remote possibility get a tiny tiny amount in when next gassed.....but given it should be vacuumed down first.....
For the valves, a wipe of 'universal lubricant' (spit) works well just as per the old checking of a tyre valve.
Detergent based soap is an oxidising agent (the reason why you should not use washing up liquid to wash a car) and hence can accelerate corrosion particularly on steel, cant see it being an issue on the alloy given it will go when driven whilst it rains (you can always hose it off anyway)
EMD
Rang stealers ....... "have you any door strap bushes" ?
Yes he says 2 in stock !
"i'll have them" ... Ten minutes later in my hand !
That's service for you  :)
Anyone who wants some Will have to wait till Monday now  :P
Omegatitis
Drove to Paddington, Parked it, drove home. Plenty of retards on the road today though!!! ::)
Lagondanet
Had it booked in for a service & MOT on Friday but summat came up and I had to make it a week Friday!  >:(
Started it up after it sat on the drive for a month.  :y
chrisgixer
First time?
I presume it must of been on charge/re charged?
Quote from: chrisgixer on 23 July 2015, 11:05:40
First time?
Second time.  :-[  Disconnected the battery.  :y
Lost a heapload of aggression on the way home. Poor thing got proper spanked. Probably knackered the speakers as well  :-[
Might have also gained a NIP this morning, reckon I should be OK as was still in a built up area but was just starting to ease power on leaving the town when the blue, yellow and white cash machine became visible from behind its hiding place.
Mrs TB was expecting a NIP following a bout of frustration with slow drivers on the Tingewick bypass (short road section I believe still holds record for the fastest speed in a successful prosecution?), but that was Silverstone weekend, and nought yet.
chrisgixer
Discovered ones alternator bearings to be rather oppsing opposed. Although a great deal of noise shows itself as not much play and slightly rough when spinning the pulley by hand. Bearings can be heard ticking over the top of the shaft as it turns. Sigh.... ;D
