pauls
Painted rear calipers and just received my pontiac front calipers from the states, just have to arrange fitting now :y
joff
Estate failed the MoT today as the washers for the headlights did not work ( didn't work last year but it passed) now fitted another pump from the parts shed which works and rebooked for Saturday afternoon.still has under 100K on it just. :y
tidla
Quote from: joff on 17 March 2016, 16:52:26
How can they test that then when they only operate now and again?
Quote from: tidla on 17 March 2016, 17:42:08
What?
On HID equipped cars they should work whenever the headlights are turned on. Part of the regulations I believe.
Quote from: VXL V6 on 17 March 2016, 17:56:56
That's what I thought.
BazaJT
I believe they work that way on all Omegas with headlight washers and did so on the Senator too.
EMD
Ripped the standard ugly radio out  :D What a bastid that cage holding it in is to get out  >:( Still a nice looking surround put in with a wee cubby hole for odss and ends underneath . Ready for the new bluetooth unit  :)
Omegatitis
Quote from: EMD on 17 March 2016, 21:58:18
Just remove the retaining screen, squeeze the cage top and bottom and it'll come straight out.
EMD
Quote from: VXL V6 on 17 March 2016, 22:06:04
It was jammed in , dont think it had ever been out before . Ended up taking the whole climate panel and surround out  :( Luckily i'd done that on another or would still be there now  ;D
Omegatitis
Sometimes some of the tabs need to be bent inwards or the edge of the top square cutout's can occasionally catch.
joff
New MoT on the Elite, just have to poly the rear and check the hand brake now.
Bikerdon
New timing belt and associated pulleys fitted, aux belt tensioner repacked with grease too as it was a bit dry, the cambelt DVD is worth every penny for someone who has not tackled this job before, all back together and running sweetly, timing on both banks was off by a small amount when the cover came off but spot on now. also found a small split in the rubber elbow on one of the vacuum lines to the bagpipes, all repaired and noticeably perkier acceleration now.
