GastronomicKleptomaniac
Hoovered all the dead pigeons and leaves out of the purple project, got it cleaned back and gave it a good coat of chassis paint. I'll have a look tomorrow to get all the bits I have missed. It's bloody satisfying getting it that much closer to the road. Tax disc ran out in 2011 so it's been a while!
countrywoman
Fitted the new front oil seal, its a bit of a bugger to do. Found a bit of tube that was a bit larger in dia than the crank ,good bit of lube and it pushed in. Found an old VW air cooled main bearing was the right size to tap it in with a large socket, timing belt on and double checked. Made a crank locking tool from scrap bits but had to borrow Ds wrench to do 250nm, then giving it the 45deg it broke my 1m long Snap on breaker bar 1/2ins drive. Its FT so that will have to do, rad in tomorrow and see if it worked. You cant tell as the outer lip hides the inner bit. Elring seal and it was better quality than the first one.
Broke the Snapon bar?! How many Weetabix did you have this morning?
countrywoman
Broke the 1/2ins square drive end , they are replaceable just have to find a Snap on van!!! Took all my strength to get the bolt to that point, 250nm plus 45deg plus 15deg . It never got the last 15!
Tried and failed to put fuel in it.  It could use some go-go juice, seeing as it was last filled in Fort William about a month ago ;D
Migv6 le Frog Fan
Put it up for sale.
The Boxster that is. The Omega isnt going anywhere.  :)
BazaJT
Changed the clutch on the V70-not exactly done in the day it took just over two weeks,but most of that was waiting for new parts to arrive to replace bits that sheared/had to be ground off.
countrywoman
Got the engine fired up in the Austin, no oil leak!!! Warms up quick as well ,temp gauge held steady at just over 90C . Found I have a coolant leak where the heater pipes bolt up to the rad core, bugger I put instant gasket on the flange as well. Trouble is its a Metro heater and they are square section O rings.
Migv6 le Frog Fan
Good result though even if theres a minor problem. We need to see some video of this little beast running.  :y
countrywoman
Top tip for fitting the front seal as its a bar steward, bit of tube slightly bigger than the nose of crank then the seal just slips on. I would but not sure how to do that on here.
Rangie
Collected our new caravan with it this morning, our previous caravan was a 2006 model had it for 14 years & it has been absolutely trouble free our new one is a 2020 & boy have things improved we're both really impressed with it, was a bit dubious about the extra width as they have gone to 8 feet wide seems much more spacious inside but on the road didn't notice any difference, so here's to a few trips away beginning next month.. 👍
Quote from: Rangie on 24 April 2025, 12:18:50
Enjoy it, Mick, summer is on the way  :y
Diesel till I die
Rangie
Quote from: STEMO on 24 April 2025, 12:39:29
Thanks Steve, wifey has been out there all afternoon sorting all the contents out now making a list of what new things we have to buy new crockery cups & saucers etc, it's a real beauty hardly had any use at all, yes indeed looking forward to the summer every month from May to September all booked, can't beat this retirement lark..
Viral_Jim
Very nice, you'll hardly have time to get to the spanish holiday casa. Not jealous at all  ::) :y
Rangie
Quote from: Viral_Jim on 24 April 2025, 18:08:43
Maybe October time for a couple of weeks, our daughter and her husband and are using it a fair bit during the summer & some friends, we just feel that we need to catch up with some friends & relatives in the  UK, we seem to be attending a lot of funerals lately can't keep putting things off.
