Sod all to my Omegas. Not even driven them.  Need to recover the Silver Bullet from Oxford at some point over the weekend.
Quote from: TheBoy on 28 June 2012, 20:34:15
What you broken on it now?  :o
Tried....and failed to remove a balljoint from a wishbone.
Ill try an engineers place locally, failing that, looks like new wishbones :(
PAULCDX
Well after two months off the road, engine work and interior change all completed the mig has just been taxed and ready for the road  8)  :y  :y
Look out Wolverhampton, the V6 power is gonna getcha!  ;D  :D
razzo
Quote from: Jimbob on 29 June 2012, 14:03:41
i found it easier to grind the heads off the rivets rather than drill em
Picked my £450 bargain 02 2.2 DTi GLS Estate up yesterday. Today i've replaced the front bumper, headlight and drivers side wing. Its now got HIDs and headlight washers, sun visors with lit mirrors and front fog lights. Just need to figure out how to replace the GID with a MID, luckily i've got an Elite that all the parts can be removed from :)
Took delivery of another bit of it..
Nope, the V12 went off with our very own 2woody for his own project.. there's a 7ltr V8 (428cu in Ford FE) going in there on throttle bodies  :y
Quote from: razzo on 29 June 2012, 19:42:24
No head left on em!
Top side free, bottom seized :(
Have a blow torch now..... round 2 commencing!
Quote from: aaronjb on 29 June 2012, 21:55:27
Hats off to that ...will keep you busy in the winter months  8)
Finished my pass side wishbone ball joint replacement...
Be glad if I never do one of those again....bugger, another one to do!
Had to drill the rivet fully out, taking head off, and heat, and hitting was not enough.
Actually, reckon just trying another one, I would do it in a fraction of the time with improved technique, not trying to do it on the car etc.  plus Ive never done a wishbone on my own before.
The old one was totally shot, no wonder it was clunking!
Vac'd and halfheartedly washed TBE. Vac'd the Silver Bullet.
Been playing with another NCDC+CID, all now depaired, just need to fix the CDC loading mech.
