Quote from: TheBoy on 12 June 2012, 13:06:10
Its stuck in a carpark "up north"
TunniEEEEEEEEE! ;D
Oh dear, was up now? :-\
Removed dead rear wishbone bushes and replaced with new shiny GM ones. So nice and firm again with the Polys. Fitted these ones back on to the car. Shyt of a job,  I never seem to manage to get the rear bolts in without wanting to set light to it :'(. Thanks to Rob for the words of  encouragement :y actually only took 5hours including fitting the new bushes :-X
Traced a coolant leak back to the recently fitted HBV >:(, tightened the jubilee clips so hope that sorted it. Time will tell though :-\
Had a good rummage around the rear suspension as it's been clonking a bit.  N/S rear shock has freed itself from the top mount, and one of the donuts isn't quite flush, might explain why the N/S rear wheel sits further back than the O/S one :-\ most of the noise is caused by the exhaust banging, all the mounts are intact but alot of play, so new ones probably in order.
Might wash it tomorrow if it's not raining ::)
Car retrieved from a Yorkshire carpark with the help of some stationary.
Who locked the keys in it then? ::) or was it temporarily borrowed and returned after the old bill found the V5 in the glovebox :-\
Quote from: taxi al on 12 June 2012, 21:46:52
It was either clamped or seized ??? :-\
Presume towed. As I'd be up to BnQ for bolt cutters or some cordless power tools if it was clamped.
markrnorton
Stripped the interior out of my 'spare' estate and still waiting for my diagnostic tool to turn up so i can fix my 2.2 !
Murph
Ordered exhaust (center and rear boxes).
One of my center boxes has collapsed and rattles like a good'un so I ordered a 3.0 setup cos it'll look better.
Only problem is I wont be able to do much with the car for a while as I broke my ankle on tuesday!
Topped up the screen wash. Checked the other fluids and pressures...
...oh, yes how could I forget. Put petrol in it.  Sigh.... :(
bootie
1 lt of oil, topped up screen wash, put new mats in, failed to get locking wheel bolt off >:(
Cleaned the wiper blades, now no smearing. Checked the lights, all good :y
Weather is a bit crap though, plus I can only get 1/2 way in the young lads garage ::)
flyer 0712
After being given the information by  o.o.f members on where to locate updated head light ajusters....Fitted new updated headlight adjuster ( thanks lads ) and was give a pair of headlight protectors and fitted them...changed orange indicator bulbs.and hoovered the old girl out..... :y
Darth Loo-knee
Fitted Bionic's rear springs that do look a hefty spring :y Lets see how the spring demolisher lass with these   ;D
My mate came down with his BMW X5 so we sorted his front wheel bearing... Plenty of precision hammering  :D
razzo
amba
Spent couple of hours this morning giving the rear diff/prop shaft and surrounding areas a thorough clean and degrease where a leaking pinion seal has been doing its best to provide rust proofing for the underside.
Not a great was to spend Fathers day :-[ but needed doing in preparation for hopefully getting the leaky seal replaced in the week  :y
