Swapped the engine loom and treated the car to its 220k service ::)
Might even wash it tomorrow :P needs 2 more front tyres as the duruns I got stuck with are absolute crap.  They've only lasted 3k which is a blessing :o floating round corners in a two ton boat has killed the outside edges. Fortunately the autogrips on the back don't really handle water either so the car actually drifts around corners quite nicely rather than simply understeeting into the scenery :-X
markrnorton
changed the crank sensor on the 2.2 , to no avail ! horrible job to. Removed the ecu for a look over and maybe replace.
grain.ben
Drove it to work and back  :P might give her a clean inside and treat her to a new smelly magic tree  :y
Cleaned, clayed, polished out some scratches (lord knows where they came from) waxed. One panel at a time. Dodging in and out of poxy bloody rain showers. Will It ever give up? :(
OmegaAnglesey
After the air-con gas had leaked out after 24H i went back today and they now say its is leaking even though they checked it twice before filling  ::)  anyways now their offering this stuff to put in to possibly fill the leak hole or whatever it is for £25 ( by saying they i mean ATS garage) and half price on a re-gas thought that was a Bl**dy cheek that i had to pay again but i might just take them up on thir offer not sure yet as it may cost ££££ to fix properly..  :-\
Seth
Stuck two new Hankook Kinergy Eco K425 tyres on the rear.
158 quid all-in. :-X
jtypecav
Cleaned it while the sun was shining!
Another wishbone ball joint on Big Blue...
Ohh how I love doing these....
OmegaAnglesey
Washed & waxed, 5 Hour job  :o  knackered now But worth every second  :y
SIR Philbutt
80k service time - Oil Change & Filter, ATF replaced, LPG filter, Air filter, Pollen filter & Bounce (see if it works), Plugs, New front disks & pads, new rear pads, Exhaust manifold gasket. Phew !!! knackered came home, fell asleep, just woke up
Tommorrow activities are,  fit a dining room radiator in the morning then cam belt and tensioner, inspect water pump, aux belt, flush and renew coolant. Then sleep
A good clean in and out and polish on Saturday - Admire work - then sleep
Lampynoiseboy
Fitted new heater control valve, due to more water falling out of the car than has fell from the sky this week.....
NOT a fun job
Fitted new MAF sensor, easy job, didn't fix the problem  >:(
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
washed and polished including alloys..just finished now.. exhausted :P
Oil and filter change on the loan van, checked it over generally and then went and swapped it over with mine so I can get my one serviced and the damage repaired ::)
Then went and spent £280 in Machine Mart on tools and equipment for the new area :'( But at least I had a VAT free voucher and saved £60 or so :y
Had to use it unexpectedly when I got home from work yesterday morning to get to Colchester in a hurry. It quickly became clear that it had a nasty misfire,on both gas and petrol. Feels very much like the misfire in my previous Mig when the dispack went down. Had to use it again late last night to colchester and back - round trip 25 miles,seemed even worse.
Donnt have time to investigate at the moment,too many other (more important) plates spinning.Expect a wanted ad for a good used dispack next week.
Glad I have the old Chavalier to fall back on.
I always have spares,but not usually the ones I need. ::)
Quote from: Albitz on 14 July 2012, 10:00:16
Given your location, try the OOF breaker in Essex...   ...oh, hold on a minute ;D
