Author Topic: So what have you done to your car today?  (Read 6916228 times)
0 Members and 13 Guests are viewing this topic.
« Reply #28755 on: 16 June 2026, 16:58:39 »
A couple of the power sockets packed up, so checked the fuses and found a blown one, changed it and all good.  :y
It should have been an easy job, but I've never seen such a stupid design for the front fuse box. There's a little hatch at the back of the glovebox and the fuses are a good 6" further in. There are cables in the way and had to change the fuse mostly by feel as you can't see inside when most of your arm is in the hole!  ::)
Whoever thought that was a good idea should be taken out in front......    Well you know the rest.  :-X  ::)
    • 530D M Sport, 330i Coupe
« Reply #28756 on: 16 June 2026, 22:31:19 »
Needle nose pliers are your friend for that fusebox.
« Reply #28757 on: 16 June 2026, 22:53:07 »
I found mine were too chunky, so I used a pair of tweezers.  :)
« Reply #28758 on: 17 June 2026, 14:54:13 »
German engineering?
« Reply #28759 on: 17 June 2026, 14:55:09 »
Talking of German engineering, dumped the Jaaaaaaagggg and picked up a V-Dub.
« Reply #28760 on: 17 June 2026, 15:54:01 »
Oh dear.....so the hairy black pussy is no more. ::)
« Reply #28761 on: 17 June 2026, 16:35:55 »
I suspect just at an airport, can't see him owning a FWD/AWD VW
« Reply #28762 on: 17 June 2026, 18:36:25 »
Correct on both counts, young'un :y
« Reply #28763 on: 17 June 2026, 21:54:36 »
Try checking a Smart Roadster's SAM/Fuse-relay box  ;) It needs lowering on its plastic 'hinges' but even then they're a PITA to access.  :y :y
BazaJT
  • SLady bitshorpe N.Lincs.
    • Omega 3 litre Elite
« Reply #28764 on: 18 June 2026, 09:44:02 »
Yesterday finally got round to going to lock up to try bleeding the Omegas brakes. Some time ago I replced n/s rear caliper after which no end of brake pumping(with two of tackling the job) would stop the pedal going straight to the floor. Big worry was an air lock in abs block. Yesterday put a newly acquired pressure bleeder on it and after a couple of hours( due to very limited clearance in the garage to get the wheels off/on) I've got a usable brake pedal again! Although it will still need money spending on it there is hope that it may return to the road later this year/early next year after 8 yrs sat in the garage.
« Reply #28765 on: 18 June 2026, 19:02:40 »
German engineering?
Das ist korrect.  ::)  :)
« Reply #28766 on: 18 June 2026, 19:42:43 »
Ran out of road....
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
« Reply #28767 on: 18 June 2026, 19:59:46 »
Ran out of road....
Very nice.  :y  Not so much run out of road, but run out of land to put it on.  :)
« Reply #28768 on: 18 June 2026, 20:12:03 »
Fortunately, just to the right, a decent set of switchbacks to lower you a few hundred metres down to the green area.  The Soviet VW had some proper hot brakes ;D
    • Grandland 1.5 diesel
« Reply #28769 on: 18 June 2026, 20:24:49 »
Diesel till I die
