badmuver
Fitted a new tie rod, now just got to do the tracking and the aircon needs to be re-gas. the garage have quoted my £50 for both   ;D
biggriffin
Hoof'land storeman.
chrisgixer
biggriffin
Hoof'land storeman.
chrisgixer
Yes it's what's in the water you know. ;)
The Sheriff
Had it washed by the east europeans at the top of the road. Good job if somewhat expensive at a fiver. They do run round like lunatics though, sponge in each hand....made me quite tired watching them.
Quote from: STMO on 29 November 2014, 19:33:54
::) ;D
STMO next time you born as an eastern european dont blame me ;D
Taxi_Driver
If you drive all the way to Swindon and pretend your a taxi.....inside and out for a £5  :y
pscocoa
changed key fob battery - first time I have bothered to do this myself. Easier than I thought as no damaged lugs etc when I opened up and no need to re sync to car.
Tried and failed to change the rear discs on next doors Octavia :-[
Stupid eejits at the factory must have welded the caliper carrier bolts in, so even on ramps, you can't get enough leverage to undo them with a two ft breaker bar >:( not that there's room to actually use a breaker bar on them in the first place :-X
I can only assume the hubs are completely built up before fitting to the rest of the suspension :-\
Taxi_Driver
Quote from: Taxi Al on 30 November 2014, 19:16:07
Had the rear pads changed on mine, not this service, service before.....10min job.....but then I didn't do it  :-\
Taxi_Driver
Did attempt to get it cleaned inside and out for a £5.....but at 4.30pm they had a queue onto the main road....so didn't bother....i'll get it cleaned tomorrow....its minging.... :-[
Did chuck £20 of diesel in it at £123.9  :y
Quote from: Taxi Driver on 30 November 2014, 19:33:29
The pads are/were a doddle, but you need to remove the caliper carrier bolts to remove the disc ::)
Makes an otherwise straightforward job a complete bastard without access to a ramp...
4x4
Finally got the truck washed today after its off roading fun and down at stables,well it was clean for about an hour but does need a good polish and waxing soon.
Taxi_Driver
Quote from: Taxi Al on 30 November 2014, 20:01:54
Sorry misread....thought you meant the pads  :-[
