Steve B
Quote from: Sir Tigger on 14 April 2015, 21:16:04
Fitted poly bush to nearside front wishbone.  :y  Watch out for the next installment tomorrow as I only had time to do one side today.  ;)
In the meantime I've been relegated to a purple Ford Fiesta.....  ;D
How long did it take  :y
Quote from: BIGtime on 14 April 2015, 21:33:09
All day by the sounds of it :D
Quote from: Taxi Al on 14 April 2015, 21:35:48
Cheeky Bastid!  ::)  ;D  About two and a half hours BIGtime.  :y
I fully expect to do the other one in about 10 minutes tomorrow!  :D
Steve B
Quote from: Sir Tigger on 14 April 2015, 21:40:50
Well done sir tigger.  :y Done you done loads of underneath stuff lately. :y
Moi... ???  ;D
No mean feat with the car on stands :y
chrisgixer
Quote from: chrisgixer on 14 April 2015, 22:36:34
Sharp jig saw blade :y
Yes mine kinda burnt it's way through the rubber rather than cut it!  ;D
EMD
Rust treated both rear arches ..  scraped out all the dirt from behind arches.
Need new silencers an back box plus front wheel bearing . Thanks to Serek for
checking what i needed  :y
Omegatitis
chrisgixer
Quote from: Sir Tigger on 15 April 2015, 00:00:04
I use a whole cutter for removing the centre, if that helps. Then go with the jig saw to cut through the metal bands.
Quote from: chrisgixer on 15 April 2015, 15:02:16
Thanks for that.  :y  All done now and it stops in a straight line!  :y
However.... see gen help.  :(
driver115
Fitted cd/radio as required iso cable and aerial adapter arrived today.Rust spots to sort out tomorrow on the micra.
Two new valves on and a puncture repair on the Alhambra, also splashed a bit of rust converter on the small spots of surface rust until I can get some time to sand it out properly.
Rain-X'd the rear window on the 3.2
New windscreen hopefully being fitted to the 2.6 on Friday ::)
Shackeng
Quote from: VXL V6 on 15 April 2015, 17:09:09
That's a good idea,  I miss the rear wiper on my saloon. :(
krabi_one
Cleaned breather pipes and plenum. fitted new thermostat and inlet pipe ( all works - but in first trial run didn't connect the one of the pipes on the front of the plenum - first thought oh no...... but in closer inspection find out that was only the pipe uffff) B Bolt hurray took me max 6 minutes. Unplug the Power sounder ( was draining battery like crazy )VX told me that new one need to be programmed to the car
few more things to do
VX dealer give me the price for cam cover gaskets £120 all together (or work done by them almost £400)
is it worth to buy the gaskets from VX or different place ?
Vx ones do seem to last better... :-\
Have a good read of the guide and order the parts as suggested :y
