Pages: 1 2 3 [4] 5 6 7   Go Down
Author Topic: Taking off battery & unplugging ECU.  (Read 13946 times)
Re: Taking off battery & unplugging ECU.
« Reply #45 on: 07 January 2010, 21:21:49 »
last copy i have of my data showed..
O2 Sensor 1      215 mV
O2 Sensor 2      254 mV
O2-Loop 1 Integrator      122 Steps
O2-Loop 2 Integrator      121
O2-Loop 1 BLM Idle (Block Learn Map)      128 Steps
O2-Loop 2 BLM Idle (Block Learn Map)      129 Steps
O2-Loop 1 BLM Partial Load (Block Learn Map)      128 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map)      125 Steps
your voltages are fairly different, and the low step count of one is strange
RossMk2
  • Dudley, West Midlands
« Reply #46 on: 07 January 2010, 21:25:31 »
Ok so i will try that, but where do we go from here?
« Reply #47 on: 07 January 2010, 21:30:38 »
check the 02 sensor connections are ok...maybe use some switch cleaner.
check exhaust is sound.
RossMk2
« Reply #48 on: 07 January 2010, 21:42:24 »
the actual connections are fine. which one would you say is adrift? with the exhaust the only way is to get gaskets and refit
RossMk2
« Reply #49 on: 08 January 2010, 08:15:37 »
Right took a reading 1st thing this morning while ice cold and it struggling to idle.
Also Jimbob you might know, i went to reset learn values and it gives you two options: O2 and IAC resets then it brings up a page of the block learn values you want to reset. Now with O2 it auto loaded most of the values i only noticed one missing which i selected from drop down list so thats not the problem, what was happening was when i pressed 'start activation' it greys out and then just stops like that and i have to press 'stop activation' to move on. Does it take some time to reset the block learn values and it was just me not giving it the time it needs?
Readings:
"My Naff Code Reader" 090714 - PC based diagnostic tool
Date and time>      08/01/2010. 07:43
Workshop information:
Please add your workshop
name in the settings window
Selected model>      1994      Omega-B      Engine      X 30 XE
Control Unit:
KW82 protocol initialized.
ECU ID= PS      90457098      261203272      1267358445      4
Measuring blocks information:
Identifier      1C
Battery Voltage      11.3 V
Immobiliser Signal      Not Received
Immobiliser      Inactive
TPS Signal (Throttle Position Sensor)      0.47 V
Simulated Idle Position      Active
Simulated Full Load Switch      Inactive
Mass Air Flow Sensor      0.82 V
Mass Air Flow Sensor      16 kg/h
Coolant Temperature      3.96 V
Coolant Temperature      9 °C
Intake Air Temperature      4.37 V
Intake Air Temperature      -4 °C
Engine Type      6 Cylinder
Transmission Coding      Automatic Transmission
Park/Neutral Switch      R-D-3-2-1  12V
A/C Information Switch (Air Conditioning)      Inactive 0V
A/C Compressor Switch (Air Conditioning)      Inactive 0V
Telltale (Check Light)      Off 12V
Fuel Pump Relay      Active 0V
Spark Angle before TDC (Top Dead Centre)      2 °CA
Ignition Coil Cyl. 1+4 (Cylinder)      Load
Ignition Coil Cyl. 2+5      Load
Ignition Coil Cyl. 3+6 (Cylinder)      Load
Knock Signal      Inactive
Knock Retard      0 °CA
Secondary Air Pump Relay      Inactive 12V
EGR Valve (Exhaust-Gas Recirculation)      Inactive
EGR Position Feedback (Exhaust Gas Recirculation)      0.60 V
Fuel Tank Ventilation Valve      0%
O2 Sensor 1      507 mV
O2 Sensor 2      449 mV
O2 Sensor Loop 1      Open
O2 Sensor Loop 2      Open
Air/Fuel Ratio 1      Lean
Air/Fuel Ratio 2      Lean
O2-Loop 1 Integrator      128 Steps
O2-Loop 2 Integrator      128
O2-Loop 1 BLM Idle (Block Learn Map)      129 Steps
O2-Loop 2 BLM Idle (Block Learn Map)      39 Steps
Hall Sensor      Inactive
Engine Speed Pulse      Inactive
Engine Speed      408 RPM
Idle Air Control      15 Steps
IAC Integrator (Idle Air Control)      170 Steps
IAC Adaptation Slope (Idle Air Control)      200 Steps
IAC Block Learn (Idle Air Control)      136 Steps
Desired Idle Air      61 kg/h
Actual Value Idle Air      13 kg/h
Desired Engine Idle Speed      1.050 RPM
Injection Pulse      5.8 ms
Engine Load Signal      2.1 ms
TPS Load Signal (Throttle Position Sensor)      0%
Vehicle Speed Pulse      Not Received 12V
Vehicle Speed      0 km/h
Intake Manifold Valve 1      Inactive 12V
Intake Manifold Valve 2      Inactive 12V
Torque Control      Inactive
A/C Cutoff Relay (Air Conditioning)      Inactive 12V
Diagnostic Request      Inactive 5V
Matchless
  • Nottingham
    • A white van
« Reply #50 on: 08 January 2010, 14:28:55 »
Why is there such a difference in the expected and actual idle air mass flows?
Is the air intake trunk intact?
No splits in the large breather pipe to crankcase?
ICV rubber boot OK?
Funny rubber seal under the plennum intact?
If manifold vacuum is also poor (17 inch ish) then I would be looking for an air leak. vacuum should be 19 -20 inch on a good engine
RossMk2
« Reply #51 on: 08 January 2010, 15:28:55 »
ICV rubber boot OK?
Well as to the breathers, the system coming from the plenum is blocked off as the intake system was spun around 180deg. There is a breather pipe coming from the breather box to vent underneath the car that may be why vacuum is different
« Reply #52 on: 08 January 2010, 17:36:48 »
ICV rubber boot OK?
this engine is in a Mk2 Astra - the ones with no front grip ;D
« Reply #53 on: 08 January 2010, 17:38:29 »
loop 2 BLM idle is still way too low.
The steps are from 0 to 255 - resetting sets to 128, obviously enough.  I would expect oll the block learns to stay around that general 110-145 ish ballpark.
  • Auckland
    • Mazda MPV
« Reply #54 on: 08 January 2010, 19:21:09 »
I don't think it has reset  :-/
  • Auckland
    • Mazda MPV
« Reply #55 on: 08 January 2010, 19:26:06 »
Am I right in thinking that closed loop operation only occurs when the engine is up to temperature and the engine under load?
I didn't think self learning would occur at idle :-/
Do the readings make more sense at 'fast idle'? (1500-2000 rpm)
RossMk2
« Reply #56 on: 09 January 2010, 10:13:22 »
No need......  ;D
So from the looks of things bank 2 is at fault. Also notice the idle speed, as i say it will not idle when cold and even when warm doesnt get to near its suggested idle value according to that data.
Do we need a snapshot of fast idle?
RossMk2
« Reply #57 on: 10 January 2010, 18:24:10 »
Date and time>      10/01/2010. 18:06
Control Unit:
Identifier      1C
Battery Voltage      11.9 V
Mass Air Flow Sensor      0.80 V
Mass Air Flow Sensor      15 kg/h
Coolant Temperature      2.67 V
Coolant Temperature      41 °C
Intake Air Temperature      4.19 V
Intake Air Temperature      2 °C
Spark Angle before TDC (Top Dead Centre)      1 °CA
Ignition Coil Cyl. 1+4 (Cylinder)      Spark
Knock Retard      0 °CA
O2 Sensor 1      107 mV
O2 Sensor 2      829 mV
O2 Sensor Loop 1      Closed
O2 Sensor Loop 2      Closed
Air/Fuel Ratio 1      Rich
O2-Loop 1 Integrator      154 Steps
O2-Loop 2 Integrator      102
O2-Loop 2 BLM Idle (Block Learn Map)      128 Steps
O2-Loop 2 BLM Partial Load(Block Learn Map)      128 Steps
Engine Speed Pulse      Active
IAC Integrator (Idle Air Control)      167 Steps
IAC Block Learn (Idle Air Control)      128 Steps
Desired Idle Air      55 kg/h
Actual Value Idle Air      12 kg/h
Desired Engine Idle Speed      1.040 RPM
Injection Pulse      5.9 ms
Engine Load Signal      2.0 ms
Thats after a reset.
Still worrying me that the idle air value is really low, might be why its not idling correctly maybe? What could this mean, that the pipe going to idle is too thin or that there is an air leak somewhere before it? I cant find one mind.
Also the what does the mV value mean on the O2 sensors as they are stupidly high.
Tony H
  • liverpool
  • Black Elites are luurvley
« Reply #58 on: 10 January 2010, 18:43:28 »
An idea I have often thought about is, to avoid any complications that could arise from disconnectng and removing the battery has anyone concidered hooking the leads up prior to removal to a boost pack. Can anyone see any problems or drawbacks doing that? :-/
  • Auckland
    • Mazda MPV
« Reply #59 on: 10 January 2010, 18:55:38 »
Have you done a compresion test?
I'm thinking that the learned values are per bank. If one cylinder in a bank is doing something that can't be measured then it could really confuse the ECU.
Pages: 1 2 3 [4] 5 6 7   Go Up
