Pages: 1 ... 7 8 9 10 11 12 13 [14] 15 16 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31378 times)
Re: Off with its head (s)!!!
« Reply #195 on: 26 March 2009, 08:36:28 »
It might be a few days before anymore gets done as I have quite a few things on!
« Last Edit: 26 March 2009, 08:38:23 by Mark »
Martin_1962
« Reply #196 on: 26 March 2009, 09:04:22 »
Part number for green snot please.
Only need oil cooler, cam belt kit and that AFAIK
« Reply #197 on: 26 March 2009, 10:07:45 »
If I remember then I will post it up tonight.
« Reply #198 on: 26 March 2009, 22:18:25 »
Ok, bit more done.
All the pipe work at the rear, cam covers, stat, transfer pipe, coolant bridge, coolant transfer pipe, B-bolt, water pump and cambelt stuff fitted.
Inlet setup fitted and breathers re-fitted
Plugs and coil packs refitted
Crank shaft sensor wiring re-routed.
And for Martin, the green snot is - 90542114
« Last Edit: 26 March 2009, 22:19:10 by Mark »
« Reply #199 on: 27 March 2009, 08:30:02 »
There is an outside chance that this might get fired up this weekend!
Martin_1962
« Reply #200 on: 27 March 2009, 13:40:03 »
Green snot ordered
Should I buy new studs & nuts?
« Reply #201 on: 27 March 2009, 15:48:38 »
Green snot ordered
No, the studs and your old nuts will be fine  :y
« Reply #202 on: 29 March 2009, 18:46:14 »
Its all back together.
Cant be started until the pair of lambda sensor blanking plugs arrive.
Managed to get the cambelt and plenum fitted today and the oil changed.
Engine under tray cleaned and fitted
Filled with fresh oil and coolant and ready to fire.
Drileld the holes in the front pipes and welded in the new lambda sensor bosses to re-locate the O2 sensors behind the cats.
So, as soon as the blanking plugs arrive, they can be fittted and it will get started and left for a good 20 minutes at idle as the followers will knock like hell until fully filled with oil again.
I will solder in some longer bits of wire for the 02 sensors as although they do reach, its a little tight and to close to the prop shaft damper for my liking!
« Last Edit: 29 March 2009, 18:48:29 by Mark »
« Reply #203 on: 29 March 2009, 19:48:19 »
Shame about the plates - it may have saved you from the misery of a 'loan' car.  I'm sure Mr Dundee wouldn't notice the 500m per week you'll put on it ;D
And posession is 9/10ths of the law ;D
« Reply #204 on: 29 March 2009, 20:28:46 »
Lol, it should go well to!
Reacon we have a 3.0 beater here particularly as the 2.5/2.6 has a lower ratio diff!
So, to summarise, its had
Headgaskets
Valve stem seals
Manifold gaskets
3.0 cams
Stage 1 port
3.0 lower manifold
Re-furbed alternator (new bearings etc)
New crank seal
New water pump
Re-sealed oil cooler plate
Re-sealed thermostat housing
Full de-grease
Flushed followers
Fresh oil
New oil filter
Fresh antifreeze
All parts fully cleaned and de-greased
Replacement engine under tray (missing and this helps cooling)
Re-located post cat lambda sensors.
All for about 250 quid.
« Reply #205 on: 29 March 2009, 20:35:22 »
Fear not, I am having the facelift!  :y
Yep, the O2 bungs should have been here last week but have not yet turned up.
Looked at my broken one quickly, the engine and box have jumped forwad an inch (secering the mounts) and hence the prop has slipped forward on its splines and is banging against the tunnel
hotel21
  • The Kingdom of Fife
« Reply #206 on: 29 March 2009, 20:42:33 »
can you not rob the sensors from your broken one to fill the holes on Mikes?
    • 530D M Sport, 330i Coupe
« Reply #207 on: 29 March 2009, 20:46:28 »
Or screw two spark plugs in temporarily?
« Reply #208 on: 29 March 2009, 20:47:26 »
I dont have any spark plugs that old!  ;D ;D
« Reply #209 on: 29 March 2009, 21:23:51 »
Ok, picture of the engine bay
The Lambda sensor mounted in its new home!
The front section showing the engine under tray fitted
And no spare bits (that I can find!)
So there you go Mick, you can sleep easier now!
« Last Edit: 29 March 2009, 21:24:39 by Mark »
Pages: 1 ... 7 8 9 10 11 12 13 [14] 15 16 17   Go Up
