Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14 15 16 17   Go Down
Author Topic: Off with its head (s)!!!  (Read 31375 times)
Re: Off with its head (s)!!!
« Reply #165 on: 13 March 2009, 08:03:16 »
hmmm, 3.2 next Mark? ::)
And by the way, is it likely all 2.6 and 3.2s will be effected?
Geff confirmed that both the 2.6 and 3.2 were affected for a short production run
Will Geff have ideas of what range of engine numbers they fell in??
He didn't know but, said it was only early units around 2001
« Reply #166 on: 13 March 2009, 21:54:21 »
No pics tonight as didn't get much done.
Cleaned a few items (oil cooler plate, transfer pipe etc), servcie the followers and primed with a bit of fresg oil.
Need to do the alternator idealy soon and get the engine bay and block cleaned ready to start putting some bits back.
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #167 on: 14 March 2009, 18:12:49 »
Went to Marks today, nice towbar he's got to fit to it.
It's been stove enamelled Silver, will look great on.
I like red cars
« Reply #168 on: 14 March 2009, 21:58:20 »
just a rather late thought, but any reason why 3.2s suffer a bit with lazy lifters when oil changes are left a bit too long and the 2.6 doesnt? or at least i dont see any 2.6 owners complaining about it...
« Reply #169 on: 14 March 2009, 22:09:12 »
No difference between the two on that one....both could suffer the same.
I have found noisey lfiters during running due to one of two things
1) Very poor servicing resulting in oil pump wear and low pressure
2) An engine that has been flushed, often the oil pickup strainer is a bit clogged.
« Reply #170 on: 15 March 2009, 20:25:04 »
Again, not much done today as I have been fitting a water softener this weekend.
Managed to get it on the road and give the engine bay a good wash down.
Aircon compressor was covered with a bag to protect the bearings, alternator was removed as its bearings are already noisey!
Filthy!
Also, managed to start stripping the alternator down.
Off with the pulley (break me tight!) nut
Removal of the 4 bearing retaining plate screws (I use a cordless drill to get plenty of sudden torque behind these to shift them as they are loctited in!)
Removal of the rear cover (this is the later type, the early versions are much easier!)
Removing the 4 main body securing screws
One of them is a little hard to get at so out with the cordless drill again!
And got, the oil cooler and oil cooler pipes re-fitted and oil filter and housing re-fitted.
Looking a bit cleaner now
Plus a few more random pics
Knock sensor number one and the starter motor
Oil level sensor and the oil pump (later type)
Knock sensor number 2
Oil filter housing location, crank sensor and the oil cooler pipe holes
Side shot of the steering box with the cabin coolant pipes poking through the fire wall
Further shot of the steering box, you can see the solenoid which varies the assistance with speed just to the bottom right of the pic
Aux coolant pump bracket....this is where the cruise box is fitted on cars wothout drive by wire throttle
« Reply #171 on: 15 March 2009, 21:01:27 »
These pictures must be transferred to Technical info section..
Will be very useful on general help, to explain things if numbered .. :y
« Reply #172 on: 15 March 2009, 21:06:39 »
I had to have some 'fit it back on therapy' today as all I have done so far is take stuff off this lump!
« Reply #173 on: 15 March 2009, 21:42:53 »
Should add, whilst the pressure washer was out, I cleaned all the cable trays etc so should be nice and clean
Matchless
  • Nottingham
    • A white van
« Reply #174 on: 15 March 2009, 23:02:54 »
Mark,
Im in CV all week being a student again (cant find my cheesecloth shirts or flares, worried I might not blend-in with the crowd). Can you wait till Sat late or Sunday to do the crank seal?
« Reply #175 on: 16 March 2009, 07:42:10 »
Mark,
Yes, I have another head to re-furb and an alternator to fix so have plenty to do :y
« Reply #176 on: 16 March 2009, 09:32:14 »
(as I couldnt reach the form last night now I can post)
very clean..
same as new car engine..I hope one day mine will be the same ::)
« Reply #177 on: 19 March 2009, 21:41:06 »
The alternator is re-furbed and re-fitted now.
The other head is stripped and had its first clean, ported and ready for its final clean before re-build. The valves are cleaned and the springs, bases, caps, collets and T-vents are also cleaned.
Once its had its final clean and check, assembly can begin.
Interestingly this head has been in the wars.....
No 4 combustion chamber:
No 6 combustion chamber:
You can see damage due to what I would guess is where the engine has gobbled some plug electrodes, perhaps Mick can confirm if this lump has had an appetite for ceramic and metal at some point in its life!
Relaity is thats its nothing more than minor grazing so wont cause any issues.
And how the compression was lost!
Its now clear that the very minor dish in the piston crown is not the cause of the compression drop....they simply fitted shallower pistons (the 3.0 and 2.5 ones come flush to the top of the bore!)
« Reply #178 on: 19 March 2009, 22:44:38 »
seem to remember some pics of some fairly buggered plugs after the rain and floods at... Newent was it?
« Reply #179 on: 23 March 2009, 10:21:32 »
Crank seal was changed with the help of Matchless and his huge torque wrench
The final head got its final clean last night and had the valves lapped in plus stem seals fitted.
So, it needs springs, collets etc +manifold and heat shields fitting plus the followers sorting and its ready to fit.
The its......'on with its head (s)!!!'
Also got an engine under tray off Mr LooKnee (thanks) to save the bottom end getting so filthy in the future plus it will aid cooling to.
« Last Edit: 23 March 2009, 10:33:06 by Mark »
Pages: 1 ... 5 6 7 8 9 10 11 [12] 13 14 15 16 17   Go Up
Page created in 0.013 seconds with 14 queries.
