V6 Cambelt party - Brackley
Started by TheBoy, 19 February 2007, 13:10:59
They are sold in pairs (the two halves are different), each bag should have two gaskets in them
QuoteThey are sold in pairs (the two halves are different), each bag should have two gaskets in them
Ta, thanks for clarification :y
Bo Bo
QuoteOK I have the gaskets & O rings  :y
The guy seemed to know what he was doing, I gave him the part no's & he asked what car & engine & then if I was doing both sides, I said yes & off he went & came back with two gasket packs & 16 O rings.
Double check you have got 4 gaskets - I seem to recall they are sold individually, and 4 required, though an EPC error implies only 2 required...
Yep four gaskets, I opened the packs just to make sure....
Bo Bo
He also said that they're not available separately for the really early models any more & that you have to get new covers?
OK, I haven't heard any more, so just checking that everyone has got all the bits they need.
The only stuff I have got is a cambelt kit, Aux belt, and antifreeze for MaxV6 (no waterpump yet Max - have you made other arrangements, or shall I try Banbury)
I have 2 or 3 bottles of antifreeze in garage, plenty of oil, some spin on oil filters etc, and 2 or 3 cans of carb cleaner.
Hopefully, everyone else has arranged their parts?  If not, let me know, I may be able to get to a dealers tomorrow.
AndersH
Sorry if I'm being a bit thick, do I need antifreeze for a cambelt change?  :-[
Bo Bo
Weather forecast has changed slightly, looking like the earlier the better, although still not too bad...
Bo Bo
QuoteSorry if I'm being a bit thick, do I need antifreeze for a cambelt change?  :-[
You do if changing the waterpump as well....
Markjay
Yes if doing the water pump at the same time... which is highly recommended as it will never be so easy to get it out again...
Alas, no more Omegas....
I would recommend a waterpump every other cambelt, so its up to you if you want to change the waterpump. If you do, its around £25 + VAT for waterpump and around £8 + VAT for 'Red' antifreeze at TC prices...
QuoteSo, currently we have the following experts lending a hand:
Marks_DTM_Calib
Laidback66
Me (expert in the loose sense ;))
And the following coming:
MaxV6 (Confirmed) - Cambelt, waterpump, handbrake, HID fix - Parts, I will get
Theolodian (Confirmed) - HID fix, G/box update - Parts, N/A
Manbafia (Confirmed) - Cambelt, waterpump - Parts, member will get
BazMV6 (Confirmed) - a check over - Parts, N/A
Kevin Wood (Confirmed) - Cruise enable - Parts, member will get stalk.
SteveD (Possible) - Autobox s/w update - Parts, N/A
Sounds2k (Confirmed) - Autobox s/w - Parts, N/A
Phil (Confirmed) - Cambelt, waterpump - Parts, memeber will get
Bo Bo (Confirmed) - Cam cover gaskets, climate bulbs - Parts, member will get
Elite Pete (Confirmed) - Cambelt, waterpump - Parts, member will get
x25xe (Confirmed) - Tech2 check, autobox s/w - Parts, N/A
And following just to say hello...
Timbuk (Confirmed)
MickDundee (Confirmed)
Those above please confirm if you're coming, and confirm the list above is correct please.
This event is now full
OK, everyone who is confirmed in list above should now have a PM with address and Multimap location.
MaxV6
QuoteOK, I haven't heard any more, so just checking that everyone has got all the bits they need.
Jaime,  I think Lb66 has it covered, I'll drop him a line to double check....
Max
Admin
Yep got it covered, along with anti freeze. :)
The Administrator.
MaxV6
Flippin eck that were quick D.
so quick, i haven't even finished writing the line......
is it like a Pratchett/Disc World reverse hangover thing......
if i now don;t send the separate "line" will it give you an awful temporal lobe headache.... one where you have to take paradoxemol to settle it??
Sorry....    i'm obviously working from a  tangental interface with reality tonight.,..
QuoteFlippin eck that were quick D.
Have you been taking RonaldMcB's tablets  :o
