Project AA.
Started by Auto Addict, 07 August 2010, 07:04:13
Auto Addict
Bit concerned about the ride height at the rear.
My 2.2 measures 70cm at floor to wheel arch, the 2.6 measures 66cm.
I like red cars
Ohhh gawd, we swapping those spring assisters over  ;D ;D ;D
Auto Addict
QuoteOhhh gawd, we swapping those spring assisters over  ;D ;D ;D
No, me and a mate took them off the 2.2 yesterday, don't fit the 2.6, different seating at the bottom of the coil.
I like red cars
Auto Addict
The good news was he managed to shift the oil filter :y
I like red cars
Welung666
Don't forget that I'm not far away if you need any help AA ;) :y
Auto Addict
QuoteDon't forget that I'm not far away if you need any help AA ;) :y
Cheers :y
I like red cars
Auto Addict
That's the oil and filter changed, filter cap was so gunged up, I had to clean it out with carb cleaner.
By the way, all you V6 owners, how do you change the oil filter, without getting it all over your hair? :-?
>:( ;D
I like red cars
Ozzie Ferret
QuoteThat's the oil and filter changed, filter cap was so gunged up, I had to clean it out with carb cleaner.
>:( ;D
My Dad gets our Gnome to do it. ;D
Weasely recognised.
By the way, all you V6 owners, how do you change the oil filter, without getting it all over your hair? :-? >:( ;D
Buy a 4 pot instead, then the only thing at risk is your lower lumbar region! ;D ;D ;D ;D ;)
QuoteBy the way, all you V6 owners, how do you change the oil filter, without getting it all over your hair? :-?
You only do that once before learning ;)
Thought 2.2 and 2.6 springs would be the same. Are the coils complete?
Auto Addict
#26
QuoteThought 2.2 and 2.6 springs would be the same. Are the coils complete?
Contacted the spring assisters manufacturer, they said according to their data, all Omegas are the same.
I have a feeling that aftermarket springs have been fitted :(
On the 2.2 the cup fitted into the bottom of the spring, on the 2.6 there is a rubber plate that the coil sits on, so you cannot fit the bottom cup into the spring, if you can understand that.
I like red cars
There are differences amongst models, but the top and bottom fittings are same.  You absoluetly sure that both rear springs are complete?
Auto Addict
In what way?
I like red cars
Noot broken ;)
Sometimes, a pic is worth......
