Project AA.
Started by Auto Addict, 07 August 2010, 07:04:13
Auto Addict
Another job under the belt, changed the brake fluid & bled the brakes.
(It was a bit difficult trying to keep my foot on the brake pedal, whilst reaching under the car to tighten the bleed nipple, but using a telescopic flexible shaft ring spanner, just managed it).
I like red cars
QuoteAnother job under the belt, changed the brake fluid & bled the brakes.
Sounds like you need a broom stick to push the brake pedal while you're round the back. Works on a Westfield, anyway. :y
There'll be nothing to do at Newent at this rate.
Auto Addict
Don't you believe it! :D
I like red cars
joshwyatt
How do you find it going from a 2.2 144bhp Omega to a 179bhp one after having a 2.2 for a long period?
I had a 2.2 CDX manual for 15 months or so, bought it with 28k, and it was very nice. I always thought it was adequate in the power department, nothing amazing but good enough. I found the extra 35bhp and 2 cylninders of the 2.6 made such a big difference. I now have a 2003 2.6 Elite manual, and find it much better to drive. It requires less effort, even when just potting about on country lanes - there's no real need to change down a gear as it has enough power.
Auto Addict
QuoteHow do you find it going from a 2.2 144bhp Omega to a 179bhp one after having a 2.2 for a long period?
Hopefully, when all the problems with it are sorted this weekend at Newent, I will say it is a far superior car, but, at the moment, can't say I've noticed a lot of difference.
I like red cars
Auto Addict
I'm sweating on a water pump arriving today, can you still change the cam belt on a 2.6 without changing the water pump?
I like red cars
QuoteI'm sweating on a water pump arriving today, can you still change the cam belt on a 2.6 without changing the water pump?
yes its optional...most of us would change every other belt change...or at the 1st when you own the car.
Auto Addict
Thanks.
I like red cars
I have a spare V6 water pump (non-gen from AutoVaux, IIRC) if you're stuck. Might even find somewhere to pack it...
QuoteI have a spare V6 water pump (non-gen from AutoVaux, IIRC) if you're stuck. Might even find somewhere to pack it...
Pop it in Mrs KW's handbag, she won't notice :P
Auto Addict
#100
Sweat over, it's just arrived, thank's anyway KW :y
I like red cars
True enough, with all the other sheight that's in there. ;D
Yeh, sounds about right, my Mrs's hand bag I am sure used to belong to Sport Billy, its the only explanation as to how she gets so much crap stuff in it.
QuoteYeh, sounds about right, my Mrs's hand bag I am sure used to belong to Sport Billy, its the only explanation as to how she gets so much crap stuff in it.
;D
Martin_1962
Sue only has two, whe has a large red one with attached monkey (looked up - Kipling) and a holiday bag called an Old Bag ;D ;D
And stuffed full of gumpf.
